Aux audio fix
Discussion in 'Audio & Video' started by YLDKIWI, Apr 8, 2013.
  1. Apr 8, 2013 at 10:31 PM
    YLDKIWI
    YLDKIWI [OP] Member
    Kyle
    California
    09 4x4 Double cab V6 4.0 Red
    5k hids Leer Canopy Primus Brake Controller Nudge bar OBD II to Bluetooth adapter paired to Asus Transformer Infinity
    2009 DBL 4x4 V6
    About 6 months ago i noticed my aux audio input was starting to play up, i would hit the DISC/AUX button, it would switch to CD but not toggle over to AUX.
    After giving it a little wiggle, it worked, but over the next few months the wiggling was getting more frequent, and aux input getting less reliable.
    I had a few hours spare a couple of weekends ago so decided to pull it to pieces and try to fix it, i figured the worst case i am out $100 for a new Jack.
    I managed to find a fix that allows me to switch across to the aux even if nothing is plugged in.
    I have used many fix it videos on here so decided it was time to give back.
    I hope this helps those in need out.
    http://www.youtube.com/watch?v=JpQhX7fvjko
  2. Apr 13, 2013 at 7:51 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Very nice thank you could you just use solder to bridge the gap?
  3. Apr 17, 2013 at 9:41 AM
    YLDKIWI
    YLDKIWI [OP] Member
    Kyle
    California
    I guess, I just had the cable handy so I used it. Would just use a lot more solder.
    Good luck.
  4. Apr 19, 2013 at 5:07 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    If you happen to have purchased the extended warranty they will replace the jack for free. This is a pretty common problem. I had mine replaced shortly after I bought it used, the jack itself becomes worn and the contacts inside "stretch out" if you will, and it won't pickup the signal that something is plugged in. Mine was really bad, to the point that even slightly touching the cord, it would switch to radio or disk because it thought it was getting unplugged.
