Aux Back-up lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HillJackJDS, Jul 28, 2018.
  1. Aug 4, 2018 at 6:05 PM
    TA 4
    TA 4 Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    The simpleist way is to tap into your reverse lights feed, however myself I prefer independent control of the lights..especially for tailgaters hahaha
    On my truck I have a direct feed going from the battery, fuse, 15a switch in cab, finally I ran the leads down to the back bumper. Just make sure to use at least 14g wire to minimize voltage drop. Look into the rigid sr-m pods if you dont go the flush mount route. They have diffused lenes and are perfect for reverse lights. If your keeping your stock bumper, flush mount pods are your best bet
  2. Aug 4, 2018 at 6:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Relay under the hood. Dedicated wire run to the back bumper.
    The reverse circuit is in the driver's kick panel, parking light fuse is behind the change tray. Single pole, double throw switch with indicator light on it. Down is on with stock reverse lights, there is a center off position, up is manual on. Manual on only works if the parking lights are on, keeps me from running the battery down if I forget. Indicator light is a must, otherwise leaving then on in traffic is a possibility.
    HillJackJDS[OP] likes this.
  3. Aug 4, 2018 at 8:44 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Thanks. Dremel with heavy duty cut off disc. Took a while with lots of filing to get it just right.
  4. Aug 6, 2018 at 10:29 AM
    dandrilla
    dandrilla Member
    Dominic
    Seattle
    07 Double Cab LB 4x4
    3 inch lift, AM nerf bars, Plasti-dip badges, Areis bull bar, KC 6in spotlights, AM stereo + sub, AM high performance Halogen headlight bulbs
    I agree with this approach but a spdt switch with an indicator is real tough to find on Amazon. They have lots of OEM type switches but they are all spst.
  5. Aug 6, 2018 at 12:48 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    You can just get a separate LED that's wired straight to the aux lights, so anytime they have power the indicator comes on. Another advantage of this is you'll know immediately if the relay fails.
  6. Aug 6, 2018 at 3:36 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Just about how I did it. I have mine wired to the battery though and no indicator light. I did leave them on driving about 30 miles once. Luckily I was towing a boat so the glare was broken up by the trailer and boat. I had turned them to stay on while I was loading the boat at night at the launch. I noticed when I turned the truck off and I still had lights behind the truck. Oops!
  7. Aug 6, 2018 at 8:28 PM
    dandrilla
    dandrilla Member
    Dominic
    Seattle
    Just finished this mod and i have a couple thoughts to add:
    1) make sure you look at the back of your bumper and strategically place the location of the flush mounts (if that's what you use). The hitch makes them really tough to screw down if you put them to close to it.
    2) there's enough rust under my back bumper and on the hitch that the spot the 7 pin connector is grounded would not work as a ground for the lights. I ended up grounding them on one of the bolts for the bumper under the plastic step cover
  8. Aug 7, 2018 at 5:20 AM
    yellow_bandit
    yellow_bandit Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    My plan to work around the 3 position switch is to use 2 pairs of lights. One hooked up to the reverse lights and one on a switch. I'm not great with wiring plus this gives me the opportunity to run white and Amber. I like keeping things simple stupid
  9. Aug 7, 2018 at 7:44 AM
    andrew61987
    I wouldn't call two full sets of independently controlled lights "simple" but whatever floats your boat :thumbsup:
  10. Aug 7, 2018 at 9:46 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It was a PITA to find. Which is why it didn't get done until I left them on by mistake. I had used a standard metal toggle switch and separate pilot light on my last truck, but really didn't want to drill holes in the dash this time. I used a Carling rocker switch. The key is to find one with an internal pilot light that can be wired completely independently, with separate terminals just for the light power and ground.
    http://www.otrattw.com/wiring/V4D2Y7NB.pdf
  11. Aug 10, 2018 at 6:28 PM
    08TacoTrD
    08 TRD Offroad
    Stole this from another thread.
    HillJackJDS[OP] and stbear like this.
  12. Aug 11, 2018 at 6:55 AM
    TWENTYCO
    TWENTYCO Tree top flyer
    Tim
    North FL
    2015 TRD Off Road 4X4 Acess Cab
    Plenty mods on many vehicles since 1982. Current: 15 Tacoma 4X4 V6 TRD OR Access Cab Pyrite Mica- Icon full stage 7, All-Pro APEX sliders & rear Expedition Springs + custom Tampa Springs leaf spring upgrades, Timbren bump stops, u-bolt flip, Road Armor front stealth winch bumper & rear steel, Warn Vr 8000, Nitto Terra Grappler 285/75/r16, Off Grid Engineering Dual Battery system, SPod 6 switch, 2 pairs Rigid D2 spot & flood in bumper, ARE Expedition Cap, bedglide,Tru Cool 45K GVW add on transmission cooler, Re-gear to 4.56, rigid rear bumper floods, scan guage II, rigid ditch lights. full size spare on matching factory wheel, seat mods/insert, CB w/magnet mount.
    Sorry if I’m late to this party but.....Spod 6 switch system so you can install once and add 6 separate circuits under the hood and one ...inside the cab switch block for future upgrades and add ons. Rigid rear bumper floods. Both the Rigid led lights come with instructions, wiring and a switch and can work on their own but when used with the Spod system it’s super easy.
    https://www.4wheelparts.com/Electrical/SPOD-6-Switch-Panel-with-Sunglass-Holder-700-Tun.aspx?t_c=72&t_s=123&t_pt=101628&t_pn=POD700-Tun&utm_source=google,google&utm_medium=cpc,cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&tf=1&scid=scplpPOD700-Tun&sc_intid=POD700-Tun&gclid=EAIaIQobChMIgofP65Dl3AIVSlcNCh1kDwAdEAQYASABEgIS1PD_BwE
  13. Aug 14, 2018 at 4:42 PM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    I want my aux bumper lights to always come on with the reverse tail lights, and I want to put the aux/tail combo on a switch for when I need the light but the vehicle is off. Could I tap 12v, put a switch inline, and tap into the red/white wire?
  14. Aug 14, 2018 at 5:12 PM
    08TacoTrD
    08 TRD Offroad
  15. Aug 14, 2018 at 5:36 PM
    #35
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Thanks. I'm trying to avoid running any more wires from the front to the rear. I want to just tap into the reverse lights at the tail. Would my original question work?
  16. Aug 14, 2018 at 5:44 PM
    #36
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @08TacoTrD looks good. Use the same fuse to feed the switch and the relay. I'd also feed terminal 87 and 30 goes to the light. Otherwise 87a becomes live when the relay is turned off.
    You can also tap the reverse light wire in the harness under the driver's side threshold. That's where i tapped it.
    @webdr that would work. However, you take the risk of blowing the fuse or worse overloading the wire. You only need one wire to go back.
    Also, use the back up light tap to turn on the relay as shown above...
  17. Aug 14, 2018 at 5:46 PM
    #37
    08TacoTrD
    08 TRD Offroad
    Gonna have to tap the reverse circuit and an always on 12v for that. Need a relay and a switch. However you want to do wire that is up to you.
  18. Aug 21, 2018 at 8:15 PM
    #38
    HillJackJDS
    HillJackJDS [OP] Well-Known Member
    Dale
    2008 Tacoma 4WD
    I would like to upgrade my 3+1 flat plug to a 7 pin trailering plug.
  19. Aug 21, 2018 at 8:45 PM
    #39
    HillJackJDS
    Dale
    2008 Tacoma 4WD
    Got some killer feedback on this post. I thank you all who have contributed.
  20. Dec 5, 2018 at 1:07 AM
    #40
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    Bumping this so i remember where to get info.
