Aux Fan mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by cal45fan, Jul 27, 2018.
  1. Jul 27, 2018 at 2:53 PM
    cal45fan
    cal45fan [OP] Active Member
    2003 Tacoma 4X4 V6
    I realize that our Tacoma’s do not have an electronic aux fan. Has anyone done this in addition to the mechanical fan?
    As hot as it is here in Phoenix and to help my AC blow colder air, I am thinking of adding an auxiliary fan. Any pointers?
  2. Jul 27, 2018 at 3:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Have you looked into changing the fluid in the fan clutch to have it kick on sooner to help out
  3. Jul 27, 2018 at 9:08 PM
    cal45fan
    2003 Tacoma 4X4 V6
    Change the viscous fluid in the fan clutch? Is that possible? Link?
  4. Jul 27, 2018 at 9:17 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ask @Speedytech7 or @mechanicjon
    Speedytech7 likes this.
  5. Jul 27, 2018 at 10:47 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Yes you can remove the fan clutch and replace the fluid with thicker stuff. I'll find a link. Just did it to mine because at idle my a/c sucked.
  6. Jul 27, 2018 at 10:48 PM
    UnderFire
    UnderFire Well-Known Member
  7. Jul 27, 2018 at 10:52 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  8. Jul 28, 2018 at 6:48 AM
    cleonard
    cleonard Active Member
    Santa Clarita, CA
    2003 extra cab 3.4L 4x4
    That kit is a uses a thermostat to activate the aux fan. That's not really what you want if the goal is better AC at idle. You want to trigger the relay with at AC compressor clutch instead.
    Even with the aux fan, part of the issue is the low idle RPM the compressor is not pumping enough refrigerant.
  9. Jul 29, 2018 at 3:31 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Fan isn’t the problem it’s the a/c, something needs service, mine blows ice cubes!, if the fan clutch were a issue the truck would overheat. Obviously thats not why you started the thread. It should be pressure tested, and if it holds, they vaccum the lines and make sure it holds vac, then they might need to top off the r134, no biggie.
  10. Jul 29, 2018 at 3:44 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    First time I’ve heard of this mod. May have to look into it. My black truck in the FL sun suffers at idle for A/C temps. Takes quite a while to cool at idle. And since I added my supercharger, my water temps have gone up 3-5 degrees at idle.
    Mech_Eng and mechanicjon[QUOTED] like this.
  11. Jul 29, 2018 at 3:59 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Were do you live?
  12. Jul 29, 2018 at 4:57 PM
    cal45fan
    2003 Tacoma 4X4 V6
    Arizona.
  13. Jul 29, 2018 at 4:59 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I'm asking @Luv my yota were they live
  14. Jul 29, 2018 at 5:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    He is from the LA are if I remember right
  15. Jul 29, 2018 at 5:26 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    If that is the case. My A/C blows ice cold at 100 degrees to. Can't compare how an A/C system in LA works to one in Phx Az At 118 degrees.
  16. Jul 30, 2018 at 1:17 AM
    tony2018
    tony2018 Well-Known Member
    can you guys put a thermoeter for accuracy? curious
  17. Jul 30, 2018 at 8:08 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Humidity is waaaay different
    Sperrunner likes this.
  18. Jul 30, 2018 at 8:25 AM
    Glamisman
    Glamisman Well-Known Member
    there is what is refered to as the "green" fan clutch for Tacomas. Some call it the HD or towing package fan clutch. It is a direct replacement for the stock one. I am not sure if there is a different fan or not. One would think with all of the Toyota pickups in the middle east that they would know about extreme heat and cooling.
  19. Jul 30, 2018 at 8:41 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    "The Toyota dealer says there are three types of viscous fan clutch silicone. They are rated at 3000 CST, 6000 CST, and 10,000 CST. (the higher the Cst rating, the higher the viscosity (THICKER fluid) All priced the same. The only reference to this stuff that the Toyota parts jock could find, was a TSB from 1975 specifying the fill procedure for the clutches of that year, The 3,000 Cst. was for all Toyotas except for the Celica (the only “sporty” car they offered in 1975), which got 6,000 Cst. The 10,000 Cst. was not assigned an application by the TSB. He guessed maybe the Land Cruiser but didn't really know. Anyway, the part numbers are 08816-03001, 08816-06001, and 08816-10001, respectively.(Each bottle is 18mL; you will probably need 2-3 bottles depending on your specific fan clutch)"
    http://www.zhome.com/ZCMnL/tech/FanClutch/FanClutch.htm
  20. Jul 30, 2018 at 1:36 PM
    Luv my yota
    00 turd lift 33's
    I live in the high desert near LA, and we get to 120* and I’ve taken lazer readings of the asphalt whilst sitting in LA traffic jams and between the cars in front of me at 125-130* with a lazer, then cars are blowing hot exhuast directly into my radiator, and the ground reading 150* in LA. The Antelope Valley is so much like AZ, 9% rh and temps hit 110-120 since I was born here 40 years ago. Do yourself a flavor and run defrost in the winter to keep the compressor lubed for optimal performance during summer, its the lack of maintenance between seasons and high/low temps that hurt you’re system. I need to knock on wood because my a/c is awesome after servicing it ten years ago, and I’m talking nipple show, lol. Seriously though, during winter, cycle that system for reliability during the summer because the lack of lube ruins compressors all day. Does the system blow even a little bit of cold air? The vents even blow air? Thanks, we’ll get her figured out, you have team backing. My friends in Phoenix AZ had issues just like you until they fixed the a/c and started to listen about winter cycling, you can do it just by running defrost.
