Aux Fuse Block
Discussion in '2nd Gen. Tacomas (2005-2015)' started by qnyla, Apr 4, 2011.
  1. Apr 4, 2011 at 8:21 PM
    qnyla
    qnyla [OP] Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    How do you guys think this would work as a Aux Fuse/Relay Block in a Tacoma?
    http://forum.ih8mud.com/merchandise-storefront/352802-auxiliary-fuse-relay-panel.html
    It looks like a nice handy splash proof fuse block. A little pricey but it would make for a clean install.
    I'm looking to use it to run some driving lights, radios, extra power outlets, etc.
    I have a Blue Sea Fuse Block in hand, but I am worried about it getting full of dirt and dust under the hood without being put into a box.
  2. Apr 4, 2011 at 8:23 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    mine has stayed clean, just dusty on the cover from 4wheeling
  3. Apr 4, 2011 at 8:33 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    my turn to show off :D
  4. Apr 4, 2011 at 8:34 PM
    PLC721
    Patrick
    Chandler, Az
    nice i like the breaker, i didnt feel the need for one since i'm not doing any like african safari trips, but maybe one day i'll add one
  5. Apr 4, 2011 at 8:35 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I don't have pics, but I have the blue sea as well, just the 6 terminal one with a negative bus.
  6. Apr 4, 2011 at 8:43 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Breaker isn't for safari trips its for if you get a short of some kind in the fuse panel or wiring to it. Breaker setup you hear a click. Direct setup you have a fire in your engine bay and your truck is garbage.
    Better hope you have fire insurance and they somehow don't find that :D
    As I posted earlier, I did bluesea as well, though I used a dist panel. Shows which circuits are on/off/blown with a switch for each. And yes I used a breaker.
    None of my wiring is cleaned up yet, don't judge meeee.
  7. Apr 4, 2011 at 8:45 PM
    PLC721
    Patrick
    Chandler, Az
    it will blow a fuse before it ignites in fire
  8. Apr 4, 2011 at 8:45 PM
    S.B.
    Sean
    San Diego
    15 Taco
    If its a first gen just keep driving.:D
  9. Apr 4, 2011 at 8:47 PM
    S.B.
    Sean
    San Diego
    15 Taco
    You can get breakers for reg size fuses. Can get auto reset, manual reset, or plain fuses.
  10. Apr 4, 2011 at 9:00 PM
    anethema
    J
    Dawson Creek,BC
    ER, no it wont, since aux fuxe panels are wired directly to the battery. There is no fuse to blow, you will have a fire.
    You are not paying attention :D
    We are talking about the circuit breaker that goes between the battery and aux fuse panel. You can see it in the pic in post number 3.
  11. Apr 4, 2011 at 9:01 PM
    PLC721
    Patrick
    Chandler, Az
    well that is why i have a fire extinguisher :cool:
  12. Apr 4, 2011 at 9:02 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I know. I was talking about the last pic, so one doesn't have to buy that monster of a circuit breaker panel.
  13. Apr 4, 2011 at 9:04 PM
    anethema
    J
    Dawson Creek,BC
    Good luck putting out an electric fire with an extinguisher! That heat ain't going away
    Tacoma -->:bananadead:
    :D
  14. Apr 4, 2011 at 9:05 PM
    anethema
    J
    Dawson Creek,BC
    Sorry SB my bad. That is not a circuit breaker panel. It is a fuse panel like the other. It just has some more features :D A switch for each circuit, and an indicator LED that tells you if the circuit is switched on and fuse ok, switched off but fuse ok, or fuse blown.
    It fits nice back there, no intrusion. And again, I'm not done wiring so much cleanup still to be done.
  15. Apr 4, 2011 at 9:05 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Thats a bannana.:D
    I'll just wish it away.:cool:
  16. Apr 4, 2011 at 9:06 PM
    PLC721
    Patrick
    Chandler, Az
    i only have a cb and a few lights wired into it, i bet i'll ne fine :) :knocks on wood:
  17. Apr 4, 2011 at 9:06 PM
    S.B.
    Sean
    San Diego
    15 Taco
    oh, I thought they where breakers.
  18. Apr 4, 2011 at 9:14 PM
    anethema
    J
    Dawson Creek,BC
    What you put on the fuse block isn't the issue. What if something comes loose in the fuse block itself, and shorts? What if the wire to the fuse block rubs on something and shorts?
    1 truck destined for the rubbish heap is the result heheh.
  19. Apr 4, 2011 at 9:15 PM
    S.B.
    Sean
    San Diego
    15 Taco
    This is true
  20. Apr 4, 2011 at 9:15 PM
    PLC721
    Patrick
    Chandler, Az
    true
