Aux Fuse Bracket Brakes conflict
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TroyFJ, Feb 8, 2020.
  1. Feb 8, 2020 at 10:19 AM
    TroyFJ
    TroyFJ [OP] Well-Known Member
    Troy
    2017 TRD OFF-ROAD
    2” lift
    Well, I went and did it. Installed an aux fuse bracket, now my power brakes aren’t working. Must have pinched a wire? Hope removing it fixes the brake issue.
    RyanDCLB likes this.
  2. Feb 8, 2020 at 10:37 AM
    caribe makaira
    Caribbean, Puerto Rico
    I see no wires to the items...
  3. Feb 8, 2020 at 10:38 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Is there an idiot light on in the dash?
    Do the brakes not work? Pedal goes to the floor?
    Shellshock likes this.
  4. Feb 8, 2020 at 10:41 AM
    TroyFJ
    Troy
    2017 TRD OFF-ROAD
    2” lift
    Yes, getting a message about ABS brakes. Went to drive away, brakes still work, but not power brakes. Have to push the pedal pretty hard.
    No wires yet, just got it installed last night
  5. Feb 8, 2020 at 10:44 AM
    eurowner
    eurowner Duke Sky
    Scoty
    The Off Road uses hydroboost for the brakes, so that is where the system gets its assist. Most vehicles uses a vacuum booster to assist the brakes. assist aka "power".
    Take off the stuff you bolted on and double check everything.
  6. Feb 8, 2020 at 12:54 PM
    TroyFJ
    Troy
    2017 TRD OFF-ROAD
    2” lift
    So, I took off the bracket. It looks like the edge of the bracket cut into the wire and grounded it. I’m still getting an error. Does ABS have a fuse?
  7. Feb 8, 2020 at 1:40 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Not sure, what does your owners manual show for fuse locations?
  8. Feb 8, 2020 at 2:01 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'm sure it does. Where though, I couldn't tell ya.
    Shellshock and GreyBaldTaco like this.
  9. Feb 8, 2020 at 2:43 PM
    caribe makaira
    johntoyota and HTOWN4X4 like this.
  10. Feb 8, 2020 at 2:53 PM
    caribe makaira
    Debur ALL the edges...maybe even add a small split hose glued to the edges...
    HTOWN4X4 likes this.
  11. Feb 8, 2020 at 2:55 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Move the bracket
  12. Feb 9, 2020 at 10:01 AM
    TroyFJ
    Troy
    2017 TRD OFF-ROAD
    2” lift
    So I replaced the 50 amp Jcase fuse, brakes are working again. I’m very disappointed with the bracket, even in the website, the picture clearly shows an edge of the bracket resting on a wire to the brake system. Poor design!
    Skydvrr likes this.
  13. Feb 9, 2020 at 10:03 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Notch it 1/4" above the harness, and remount it.
    oconnor and Skydvrr like this.
  14. Feb 9, 2020 at 10:20 AM
    caribe makaira
    Remove it. Do the notch. File/sand smooth all the cuts, especially the areas where the wires will pass n rest.
  15. Feb 9, 2020 at 10:25 AM
    TroyFJ
    Troy
    2017 TRD OFF-ROAD
    2” lift
    Good idea. I cut the bracket. Still a little close for comfort, but it should be ok
  16. Feb 9, 2020 at 10:35 AM
    caribe makaira
    Is that an (5032) ST Blade Split Bus Fuse Block?
  17. Feb 9, 2020 at 10:45 AM
    TroyFJ
    Troy
    2017 TRD OFF-ROAD
    2” lift
    Yes it is. I want two power sources, one always on for the light bar, a usb charger, and one that switches off with the ignition for the ham radio and dash cam.
  18. Feb 9, 2020 at 12:41 PM
    caribe makaira
    Look what Blue Sea System has for April...
    The internal is similar to the 5045 fuse block...
  19. Feb 10, 2020 at 11:30 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    OP regarding the Overland Equipped fuse bracket, thank you for making this post. You probably saved me a future headache! I thought the wire was close, but didn't take any precautionary measures. I checked, and I had about 1/8" of space between the wire and the bracket. A quick fix for now was to cut a rubber fuel line hose and zip tie it around the wire. :thumbsup: Thanks again! By the way, did you reach out to Overland Equipped?
  20. Feb 10, 2020 at 11:50 AM
    caribe makaira
