Aux In Volume Boost
Discussion in 'Audio & Video' started by andrew862, Mar 4, 2011.
  1. Mar 4, 2011 at 2:22 PM
    andrew862
    andrew862 [OP] Well-Known Member
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    Downey SST Tonneau, DeeZee Bed Mat, TRD Exhaust, ScangaugeII
    Just connected a PHP Sound Shocker inline passive signal amplifier between my XM Sportscaster and the AUX In port on my OEM headunit. My sportscaster typically required the volume set at 50+ to hear comedy clearly at highway speeds. If it was music there essentially was no way hear it with the windows down from the XM unit. With the PHP unit I am getting adaquate volume at 25-30 now. If I turn it up to 50+ it is Too Loud. Now my XM Radio is more similar to normal FM radio volume levels. The PHP unit also seems to have filtered out some background static/hiss that was always slightly audible using the XM unit.
    Here is the PHP: http://phpaudio.jigsy.com/passive-preamp
    It is probably the best $30 I have spent recently. It does not require any setup, it uses no power, it is freaking cool. If you are frustrated with the volume of the AUX-IN port you need this device. :)
  2. Mar 4, 2011 at 2:38 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    I got one let c if it's worth $30
  3. Mar 6, 2011 at 2:34 PM
    DevL
    DevL Well-Known Member
    If you hear less hiss its because the amp is not turned up to as high of an output, not because its filtering anything.
  4. Mar 6, 2011 at 5:21 PM
    andrew862
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    Perhaps, but there is actually less noise when I turn the volume on the head unit up near max. I am not sure if the device filters, but it does have a high frequency cutoff above which it is not boosting signal which may help eliminate some hiss.
    Either way, less noise is A OK with me :bananadance:
  5. Mar 6, 2011 at 6:25 PM
    ZZT
    ZZT Member
    You are correct. In addition to that Sound Shocker provides transformer isolation which helps to block out electrical engine noise.
  6. Mar 10, 2011 at 10:02 PM
    Tac 2009
    Tac 2009 Well-Known Member
    black 09 SR5
    awesome. This is great- I'm going to nab one.
    everyone talks about taking apart their interiors or buying other FM add ons- why? lets use whats there already
  7. Mar 15, 2011 at 9:02 AM
    Femino
    Femino Member
    Boston, MA
    SR5
    Just ordered one. No shipping info on paypal. How did it take to come in? Does it come with any cables.
    Thx
  8. Mar 15, 2011 at 9:47 AM
    andrew862
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    Mine took 2-3 days to arrive. It comes with one cable that is several feet long if I recall correctly.
  9. Mar 15, 2011 at 10:05 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Did you get the sound shocker or the sound shocker II?
    I have the 05 radio with a cheap ipod adapter. the volume on that is super low. This will work the same, yea?
  10. Mar 15, 2011 at 6:39 PM
    andrew862
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    I have the regular SoundShocker.
  11. Mar 15, 2011 at 6:43 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    I got sound shocker II
  12. Mar 15, 2011 at 6:51 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea I just submited a comment for the shocker 2 three foot long
  13. Mar 24, 2011 at 10:17 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Mine just came in. Works like a charm!
  14. Mar 25, 2011 at 8:33 AM
    Femino
    Femino Member
    Boston, MA
    SR5
    Not really thrilled with mine.... It ceratinly increased the volume, but I'm getting some crackling noises with certain tracks from the ipod. Could be the quality of the file from the download....
    I think I'm going to go with an after market system. This is my first Toyota, and I'm very surprised that they skimp on the audio system when every other aspect of the vehicle is top-notch. :confused:
  15. Mar 26, 2011 at 8:48 PM
    Tac 2009
    black 09 SR5
    make works pretty well.
  16. Apr 1, 2011 at 5:27 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I'm going to get the II so I won't need more cables. Anybody verify that it works just as well? Thanks for the link OP! This has been bugging me for 2 1/2 years now.
  17. Apr 22, 2011 at 7:33 PM
    06silverbullet
    06silverbullet Active Member
    Salem, SC
    2011 Sport DC 4X4
    3" Toytec w/ AAL's. GT Covers seat covers, Weathertech floorliners, 3M tint, Century Ultrasport cap w/ Yakima load warrior basket.
    Been having the same damn problem, ready to throw mine out the window. Just ordered one of these as well, maybe it will do the trick.
  18. May 12, 2011 at 9:40 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Subbed incase I need to find this for someone someday
  19. May 12, 2011 at 12:27 PM
    romeo
    romeo Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    just ordered mine, heard good things so far so lets hope it works good
  20. May 12, 2011 at 10:49 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    It helps boost the sound .. Good upgrade
