AUX Input Problem (JBL)
Discussion in 'Audio & Video' started by JFKLives, Jul 12, 2011.
  1. Jul 12, 2011 at 3:06 PM
    JFKLives
    JFKLives [OP] Byte Me
    San Jose, CA
    2015 4x4 TRD Sport Extra Value W/JBL
    FJ Team Trail Red on Black Wheels P265/75R16 BF Goodrich Tire, color match front emblum, debadged and Fold-A-Cover G4 Elite
    Has anyone experienced problems with their AUX input jack? Mine appears to be having challenges where the slightest bump breaks the connection and forces it over to CD. Was ok for a while if I was careful with my droid placement but now it's so sensitive that it's becoming unusable, which is really pissing me off.
    It's not the cable. I've extensively tested with the truck parked, several cables, and flicking the jack lightly to demonstrate the root issue.
    I know there can't be much too it, something is more than likely lose but I can't figure out how to get back there. Anyone know how to get back there so I can screw with the wiring and more than likely make it worse?
    Thanks in advance! :cookiemonster:
  2. Jul 12, 2011 at 3:16 PM
    JFKLives
    San Jose, CA
    Dammit ... that's not what I want to here :confused:
    On a side note ... I can't help but to smile every time I see your truffle shuffle ;)
  3. Jul 12, 2011 at 3:24 PM
    JFKLives
    San Jose, CA
    What do you mean by a USA Spec unit?
    *edit* .. nm .... http://www.usaspec.com/
  4. Jul 12, 2011 at 3:30 PM
    JFKLives
    San Jose, CA
    That might be an option. How do I get back there? It's vastly different than my 99.
  5. Jul 12, 2011 at 3:32 PM
    JFKLives
    San Jose, CA
    Here's the grom info in case anyone else is interested
    CarMake Year Qualifier USB adapter SKU iPod adapter SKU AUX adapter SKU Cable SKU
    Tacoma 04-10 All GROM-U2i-TOY GROM-i3-TOY GROM-A-TOY TOY
    Tacoma 98-03* all GROM-U2i-TOY GROM-i3-TOY GROM-A-TOY TOY1
  6. Jul 12, 2011 at 3:37 PM
    JFKLives
    San Jose, CA
    Rad - you are a pimp
  7. Sep 7, 2011 at 8:24 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    im having the same problem, is there a replacement part for the AUX that is similar to the stock one? I would like to keep it with the AUX cable; not in the glove box...if that makes sense
  8. Sep 8, 2011 at 8:27 AM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    You could try to replace the aux jack... My guess is that the jack is worn out and not making a solid connection to the aux cable.
  9. Sep 8, 2011 at 12:11 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    good info. thanks!
    i will be trying to fix the problem this weekend.
    rep added:cheers:
  10. Sep 8, 2011 at 12:35 PM
    JFKLives
    San Jose, CA
    I still haven't figured out how to get into that portion of the console. I took out the radio and the entire center console without success :-/
  11. Sep 8, 2011 at 12:48 PM
    fbconvert
    Brian
    Seacoast, NH
    I pulled out my radio and then reached in with my hand behind the jack and pushed the tab down. It should pop out of the dash, then disconnect the pin housing.
  12. Sep 8, 2011 at 1:02 PM
    JFKLives
    San Jose, CA
    hmmm... think I tried that but couldn't fit my hand through there. Will give it another go ... thanks!
  13. Sep 9, 2011 at 7:59 AM
    fbconvert
    Brian
    Seacoast, NH
    No problem glad I could help. Since replace the jack will require soldering you might be able to stick a fine needle or something in there to bend the leads up a little so it makes a better contact with the input cable instead of replacing it, but my guess is that would only be a temporary fix.
    It was tricky when I removed mine, I had to use some forces while pushing the tab on top of the jack in at the same time. I don't believe that panel is too hard to remove though. I think it will require removing the center console and maybe a bolt or two by the driver's right knee.
    Here are some OEM procedures, you don't have to remove the every panel in the procedure but it does show where the clips are for the panel you want to remove and a the steps to remove it.
  14. Feb 11, 2013 at 5:38 AM
    HomerLovesFire
    HomerLovesFire Well-Known Member
    Hagerstown, MD
    09 PreRunner SR5 TRD Off-Road
    Having the same issue with my 09 Tacoma. Aux input with the slightest touch goes to cd, and occasionally even makes the radio just turn off. It's super annoying. I'm gonna pull the dash off and see what I can do. Thanks for all the info. Maybe this can be my excuse to finally mod my radio.
  15. Feb 11, 2013 at 12:36 PM
    JFKLives
    San Jose, CA
    My resolution came from OEM replacement. It was covered under my warranty. If yours is still current, I'd go that route - otherwise, you'll need to replace the unit yourself.
  16. Feb 19, 2013 at 10:20 AM
    HomerLovesFire
    Hagerstown, MD
    I pulled the aux jack out and bent the leads out to make a better contact. I used a small flathead screwdriver. Like one you would use on a pair of glasses. This fixed my problem. Seems like over time those two metal leads on either side bend inward and cause a slightly loose connection. We will see how this holds up in the long haul. But for now problem solved. Thanks for all the good info.
  17. May 4, 2017 at 12:59 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Hey guys,
    Been running into this problem myself, did a bit of research and it could be the result of two problems:
    1) soldering connection broke, wore, bad solder
    FIX -> https://youtu.be/JpQhX7fvjko
    OR
    2) the black back piece that is right behind the aux cable keeps shifting everytime you plug in the cable
    Potential fix (am testing it tonight)-> https://youtu.be/DNFHwVOoqwU
    if you guys try these, they may help! let me know!
  18. Oct 16, 2017 at 3:30 PM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    I'm having the same problem... I lose my mind every time it happens... haha
    Out of these, what's the best fix?
  19. Oct 16, 2017 at 4:50 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    depends, whats your symptons?
  20. Oct 17, 2017 at 7:22 AM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    The connection is very sensitive. I know the cord is not the problem as I have changed it out multiple times.
    When I hit a bump or shift gears while driving most of the time my radio switched to FM radio or turns off.
    I then have to twist and play with my AUX cord for it to get a connection and play music.
    Also, sometimes music only comes out of the passenger side speakers. Then after I tap the cord near the plugin, the music comes out of all speakers.
