Aux Lights Switch Location on a 2011
Discussion in 'Lighting' started by spayn141, Feb 9, 2011.
  1. Feb 9, 2011 at 1:04 AM
    spayn141
    spayn141 [OP] Member
    Paul
    Greenville, SC
    '11 DC TRD OR
    I've been looking through the forum for a while now, and I keep striking out. I'm sure it's been asked before, but here it goes again. I have an '11 off road, and there are no open switch blanks to the left of the steering column. What options do I have for an aux light switch? Is there a multi function switch out there that I could replace the fog light switch with to operate both? The only other thing I could think of is having it beside the "A-TRAC" switch below the cigarette lighter. My memory is failing me right now, and I can't remember if there is a blank there. If so does anyone know what switch would fit there? I believe that the A-TRAC switch is more square than rectangle like the ones by the steering column. Thanks in advance.
  2. Feb 9, 2011 at 1:21 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    My PIAA lights came with a switch with double sided tape on the back. I just stuck it to the left of the steering column opening on that section of open grey plastic. It's clean. I was going to run a switch down by the A-TRAC (there is a blank) but you can't get to that section without pulling some of the dash apart.
  3. Feb 9, 2011 at 9:43 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    I just installed a switch for my VisionX lights in the blank between the ATRAC and AUX input, and I didn't have to take apart anything. I carefully pried out the blank (then cut it up to fit my switch.) I used a fish-tape to get the wire threaded over to the area under the steering column. It was quite easy actually.
  4. Feb 9, 2011 at 10:29 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
  5. Feb 9, 2011 at 1:25 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    LOL well then you're more talented ... and certainly less lazy .. than me. :D
  6. Feb 9, 2011 at 2:22 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
