Aux power. Dual battery sys vs portable
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yawkub, Feb 15, 2023.
  1. Feb 15, 2023 at 1:41 PM
    yawkub
    yawkub [OP] New Member
    22 ORLB
    Looking to upgrade auxiliary power primarily for camping, specifically running a cpap, and charging devices.
    Eventually I will add light bar, ditch lights, fridge (maybe), all the cool kid toys.
    Trying to learn and figure out energy draw, battery size needed, etc. has got my brain all jammed up. I just want a rechargeable power source (done right) that is reliable and won’t burn my truck to the ground
    Suggestions, thoughts, setups? TIA
  2. Feb 15, 2023 at 1:59 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Sounds like the first thing to do is find out the needs of your CPAP. Can you take a look at the specs for volts and watts? Maybe give us the model information and we might be able to find it online. I think most of those are 110v, which can be pretty power hungry. Let us know!
    I have done triple batteries in my truck, as well as run a few different portable power units.
    yawkub[QUOTED][OP] likes this.
  3. Feb 15, 2023 at 6:46 PM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    On my 2006 Taco, I used an . I had to replace the PC1700 a few times as expected but that system worked great for 16 years.
    in 2016 I added a 50W solar panel
    The main load on the battery was an electric blanket on an inverter that kept my wife warm and happy.
    On my 2022 Taco, I'm using the same Odyssey PC1700 and 50W solar panel. But I scrapped the dual battery setup in favor of a lithium jump start battery that offers more versatility.
    I installed three separate auxiliary fuse/relay blocks (engine bay, cab, and taillight) to support power loads in each of those locations. You can find my summary of that setup and links to the details or each here.
    Hope this helps...
    yawkub[OP] and jackn7 like this.
  4. Feb 15, 2023 at 6:53 PM
    yawkub
    22 ORLB
    Running a Resmed S9 Elite at 18cm H2O. Their chart says (if I’m reading it right) can draw 0.9 amps @12V DC without humidifier calling for a battery size of 11-13 AH. With humidifier (which I’d like to use draws A LOT) can draw up to 6.59 amps @ 12V DC calling for a battery size of 79 AH
    the sticker on the back of the machine has:
    DC 24V
    1.25A (FG)
    3.75A (SYS)
  5. Feb 15, 2023 at 7:22 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    I would be sure to use a Resmed DC adapter. I bricked my S8 Escape trying to use an adapter I had for my old Respironics CPAP :anonymous:
    When camping I don't bring my humidifier because as you mentioned it draws a lot of power. I use this heat/moisture exchange thing that helps keep the dryness down. https://www.cpap.com/productpage/heat-moisture-exchange-unit
  6. Feb 15, 2023 at 7:29 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I’ve never seen one of these before. Does it stop your nose from drying out? That was always my problem not using the humidifier. Not trying to hijack OPs thread, but really curious.
    yawkub[OP] likes this.
  7. Feb 15, 2023 at 7:54 PM
    slowpoke16taco
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    It makes a difference vs without anything, but not an equal to humidifier. You can use it for about 5 to 7 straight nights before you need a new one. Totally worth it for weekend camps or traveling.
    jackn7[QUOTED] and yawkub[OP] like this.
  8. Feb 19, 2023 at 9:06 AM
    yawkub
    22 ORLB
    Thank you to all who provided info and insight
