Aux Power Outlet(s) Wiring
Discussion in '1st Gen. Tacomas (1995-2004)' started by jarvis, Jan 14, 2022.
  1. Jun 11, 2022 at 11:16 AM
    billpete
    billpete Well-Known Member
    Hendersonville, NC
    Had a 2002 DC, now a 2004 DC.
    Thank you for the quick reply! I should clarify my question--I would like it to run like the outlet does; when the power is on, the gauge works.
  2. Jun 11, 2022 at 11:18 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I recall one of my outlets running when the accessories were turned on via ignition. I'm sure you can achieve what you're wanting to do by tying into the correct outlet.
  3. Jun 12, 2022 at 6:35 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Depending on the current draw of the gauge .
    Tap off the Radio Fuse that will give you switched power.
    That works with the ignition switch in run or accessories.
    Always use a inline fuse.
  4. Jun 13, 2022 at 11:58 AM
    billpete
    Hendersonville, NC
    It can draw 4-28v. Pretty flexible. I think that I got it in okay. I am going to clean things up here in a bit and I will try to get a picture up.
    Thank you for the help, guys.
