Aux reverse lights blowing fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trdNick, Jan 16, 2012.
  1. Jan 16, 2012 at 6:50 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You could also use two relays.
    Wire the second relay's 30 and 87 terminals to the first relay's 30 and 87. Wire the second relay's 86 terminal to either the switch or the reverse circuit, whichever one you decide. Keep one of the two wired to the original relay's 86 terminal. Ground both relay's 85 and you should have the desired operation.
