Aux Switches Constant Power
Discussion in '4th Gen. Tacomas (2024+)' started by jrich44, Apr 4, 2025.
  1. Apr 4, 2025 at 4:17 AM
    jrich44
    jrich44 [OP] Well-Known Member
    Jared
    Des Moines, IA
    2024 Tacoma TRD Sport 6-MT
    The auxiliary switches/circuits that are provided in the 4th Gen are normally only powered with ignition on. Has anyone tried to alter these so they have constant power? Is there a way to bypass the relay to do this?
    I ask because I have a few accessories in mind that I would like to be able to use without the ignition on.
    Rover31 likes this.
  2. Apr 4, 2025 at 5:05 AM
    Iqudayo
    Iqudayo Well-Known Member
    Antonio
    Toyota Tacoma
    In reference to your question their might be, I know Rams you can manipulate what want by moving the fuse over one spot. In other words some fuses have 3 plugins (a) (b) (c) so if you unplug from a,b and replug to b,c you go from ignition power to constant power.in wonder if it works with our trucks I haven’t tried yet.
  3. Apr 4, 2025 at 5:26 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Connect to the battery. Have the switch close to the accessory. Have a fuse somewhere in that line.
  4. Apr 4, 2025 at 5:33 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You need to track down the wiring diagrams for your truck. If you can find the controlling relay(s) in question you might be able to do a mod something like this
    https://www.tacomaworld.com/threads/always-on-power-outlet-relay-modified.407458/
    There is also a version of that mod where the contacts are 'jammed' closed with something like a thick ziptie - no soldering needed. 100% reversible.
  5. Apr 4, 2025 at 12:27 PM
    jrich44
    Jared
    Des Moines, IA
    That’s how an auxiliary fuse box on my motorcycle works. It makes it very convenient to change circuits between switched and constant power.
  6. Apr 4, 2025 at 12:29 PM
    jrich44
    Jared
    Des Moines, IA
    I would usually follow an approach like this, using an auxiliary fuse/relay box. This time I’m hoping to use the circuits that are already provided for auxiliary use. I think they just need a slight modification to have constant power.
  7. Apr 4, 2025 at 12:32 PM
    jrich44
    Jared
    Des Moines, IA
    Thanks for the link. This is along the lines of what I was thinking. It should be as simple as changing the relay that is ‘normally open’ into a ‘normally closed’ configuration. The three relays for the AUX1, AUX2, and AUX3 circuits are located in the fuse box under the hood on the driver’s side. I’ll play around with a multimeter this weekend to make sure this approach will work.
  8. Apr 4, 2025 at 12:39 PM
    jrich44
    Jared
    Des Moines, IA
    Thanks for the response, but I’m not sure I follow what you are trying to explain. I don’t see how the heated seat circuit has anything to do with the AUX circuits. I think manipulation of the relay should be all that is needed to provide constant power to the AUX circuits.
    Do you see any problems with altering the relay from a ‘normally open’ configuration to an ‘always closed’ configuration. This could be accomplished by mechanically closing the contacts, or maybe replacing the relay with one that is ‘normally closed’ and removing one or both of the terminals that would make it open when it sees ignition power.
  9. Apr 4, 2025 at 12:52 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Just plug it directly to the battery. DONE.
  10. Apr 4, 2025 at 12:58 PM
    jrich44
    Jared
    Des Moines, IA
    I wish it were that easy. On my last truck I had to do that approach, but I did it with an auxiliary fuse box to have a quality end result. https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
    I think I can avoid an auxiliary fuse box by simply using the provided circuits. I poke around with a multimeter this weekend to verify. I just thought I’d post here first to see if someone else has already confirmed my thoughts.
  11. Apr 4, 2025 at 5:22 PM
    caribe makaira
    Caribbean, Puerto Rico
    That statement tells me you don't know what your doing.
    So I'm out...
