Auxbeam 4" LEDs
Discussion in 'Product Reviews' started by Tacotaco77, Mar 10, 2016.
  1. Mar 10, 2016 at 5:29 AM
    Tacotaco77
    Tacotaco77 [OP] Well-Known Member
    An example photo of the product:image.jpg Just installed a set of these on my truck, very pleased with brightness, quality and price. Bought off Amazon for $20.00. Received in a box, lights are warped in a protective foam, instructions and hardware included. Very bright led, I tried to look at them while they were on and could not.
    Thelgord likes this.
  2. Apr 7, 2016 at 6:52 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Anyone else try these yet..?
    I was just about to order a set..
  3. Apr 9, 2016 at 10:22 PM
    Tacotaco77
    Uh- ME! I can report that these lights continue to work flawlessly. Don't believe me, spend $20 and see for yourself.
  4. Apr 10, 2016 at 5:54 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    Sweet thanks for the review.
    :thumbsup:
  5. Apr 10, 2016 at 10:09 AM
    Tacotaco77
    No problem
  6. Apr 14, 2016 at 5:13 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    How did you connect? My lights are going to be mounted on ditch light brackets..since they're only 18w each what kind of quick connect can i use?
  7. Apr 15, 2016 at 2:43 AM
    Tacotaco77
    That connection you show would work, my only concern would be corrosion. You can either go to Amazon and buy waterproof connectors or just run your connects into the cab within easy reach. I hard wired my lights to a switch in the dash, used an inline fuse as well as a tap a fuse to power the switch. Use security bolts/nuts to secure your lights to prevent theft, as I'm sure your aware of.
  8. Apr 15, 2016 at 4:21 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    Sweet thanks
    Live in maine. More animals than humans
    :rofl:
  9. Apr 19, 2016 at 5:55 AM
    Tacotaco77
    I drive for a living, no explanation necessary. Just used these lights last night, I was working in the yard and it got dark, I used them to light up the area. Very pleased. The neighbor was impressed as well. I think I'll see another set of these in the neighborhood soon.
    ChemDawg[QUOTED] likes this.
  10. Apr 19, 2016 at 6:29 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    What wire gauge are you using to connect to the lights.?
  11. Apr 19, 2016 at 6:37 AM
    Tacotaco77
    I used 14 gauge from the front to the back but it was thick, so I used 16 and feel it's good but 18 would work as well. Wire loom and zip ties are a must.
  12. Apr 19, 2016 at 6:43 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    I got some 20ish gauge from my led bedlighting and from strips in footwell..
    Just not sure if I can use my wire from that project..
  13. Apr 19, 2016 at 6:44 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    For my power I'll run some 16gauge.. but from my switch to the ditch lights I was wondering if I could use the 20ish gauge.
  14. Apr 19, 2016 at 6:46 AM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Mine were $18 on Amazon. They are a bit different though.
    They are great lights
  15. Apr 19, 2016 at 6:54 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    ....what wire size did u use @TommyG ?
  16. Apr 19, 2016 at 7:16 AM
    Tacotaco77
    Are those the same brand?
  17. Apr 19, 2016 at 7:24 AM
    Tacotaco77
    It seems a little thin but I'm by no means an expert. Personally I wouldn't go smaller than 18 gauge but if you use a 3 amp fuse and something goes wrong it should blow before any damage is done. Your using two 18 watt lights so keep that in mind.
  18. Apr 19, 2016 at 9:28 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    3x3
  19. Apr 19, 2016 at 9:29 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I think. Just different style
  20. Apr 19, 2016 at 9:30 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Just make sure the silicone that the plastic sits on fully seals the channels
