Auxiliary fuel tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Old dog's taco, Apr 1, 2024.
  1. Apr 1, 2024 at 12:24 PM
    Old dog's taco
    Old dog's taco [OP] Member
    Tony
    Oregon
    Mica 2dr base 4x4
    New interior, off road lights,wheels &tires , stereo smoked tail lights, tinted windows,fog lights off road shocks
    Anyone ever mount an auxiliary fuel tank where the spare tire is located?
  2. Apr 1, 2024 at 12:32 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Seems like an explosively good idea. I think Ford thought it was also a great idea in the Pinto
  3. Apr 2, 2024 at 4:32 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    It'll take a bit of work on your end, but you can try this kit from JD Fabrication. Seems pretty straight forward but you'll have to source the gas tank or fuel cell, whatever you choose.
    -J
  4. Apr 2, 2024 at 5:09 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    A lot of vehicles had fuel tanks in the rear and didn't have problems. That was a Pinto problem.
    I have a BIL that found one in a scrapyard that would work on his 1982 F150. He bolted it in and ran the fuel filler behind the license plate which he mounted spring loaded. He wired his up to pump fuel from the auxiliary tank into his main tank after it got low. It worked pretty well for him.
    He still has that truck but hasn't driven it in about 20 years.
    Old dog's taco[OP] likes this.
  5. Apr 3, 2024 at 12:04 AM
    TacoTuesday1
    SD CA
    I wonder if that’s compatible with archive hammer hangers lots of folks already have and high clearance cross tube.
    I’m guessing hangers yes cross tube no. Which sounds fine because that tank kit looks like it braces the same way the cross tube would.
  6. Apr 3, 2024 at 4:49 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I'm not sure about that. You may be able to fabricate a custom cross tube to route around the tub. I was on the fence about doing the JD fab kit but I already have the LRA extended range fuel tank so it may be a bit much for my purposes. I haven't written it off completely yet though but it's not priority currently.
    -J
