Auxiliary fuel tanks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DryCreek, Jan 26, 2014.
  1. Jan 26, 2014 at 11:51 AM
    DryCreek
    DryCreek [OP] Well-Known Member
    Utah
    08 DCLB TRD Sport
    Pioneer AVH-X2600BT Fog Anytime Trailer Plug Relocate (bullaculla) Ride Rite Air Bags OEM Roof Rack Rearview Camera Wet Okole Seat Covers Maxpedition Holster SOS Sliders Washable Cabin Filter Access Bed Cover K&N Drop In Filter Rearview Mirror Relocate (ImMrYo)
    Looking for some options on supplemental fuel options. Ideal would be a fuel tank and tool box combo. I have been searching around for some options or pictures of what some have done with not much luck. I am thinking of having one built at this point.
    Let's hear what you guys do for extra fuel. I know there is a lot of options just haven't found what I am looking for.
  2. Jan 26, 2014 at 8:25 PM
    DryCreek
    Utah
    08 DCLB TRD Sport
    Someone out there has to be rocking a transfer tank in the bed. Where's the equipment operators at out there?
  3. Jan 26, 2014 at 8:27 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    i had a customer that went on very long hunting trips and wanted a aux tank in his tool box so we got a tank for the bottom of the tool box that had a hose with a valve that would go into the stock tank. When the tank ran empty he would get out and turn the valve to fill it up again. worked very well
  4. Jan 26, 2014 at 8:28 PM
    169.254.255.201 Well-Known Member
    Interwebs
    I've seen some toolboxes online, but they run a high price. $850^
    Not sure if anyone on here is running one, sorry
    I don't know the weight of fuel, but if your wanting to put a decent storage tank, your going to have a bit of weight in materials plus whole lot of weight in fuel.
  5. Jan 26, 2014 at 8:32 PM
    DryCreek
    Utah
    08 DCLB TRD Sport
    That's what I am looking for. What kind of tank did u use? Custom built? How did the fuel transfer? Any pump or gravity fed somehow? I have a idea in my head of building a custom tool box with a 20-25 gallon tank in the bottom. Transferring is what I need to figure out. Don't really want it plumbed in.
  6. Jan 26, 2014 at 10:15 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    If the tank is in the bed, and thus higher than the stock fuel tank, a hand-primed siphon would work fine.
  7. Jan 26, 2014 at 10:26 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why don't you get one of those Aussie long range fuel tanks to replace your factory tank or are you looking to be sble to transfer fuel to another vehicle ?
  8. Jan 26, 2014 at 11:53 PM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Some tanks are not rated for gasoline... Diesel only.
    This is probably what you're looking for.
    My old work-truck had one just like it bolted to the floor of the bed right behind the cab, and a (shallow) tool-box was bolted to the bed-rails tight up against the slip-tank.
    http://www.northerntool.com/shop/to...tural&cm_cat=netconcepts&cm_pla=Google&cm_ite=
  9. Jan 27, 2014 at 1:17 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    You might look at this;
    http://www.transferflow.com/
    I would remind you that gas weighs about 6.25 pounds per gal. @ 72 degrees so keep that added weight in mind.
