Auxiliary Port and Ipod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaMike37, Feb 18, 2014.
  1. Feb 18, 2014 at 12:05 PM
    TacomaMike37
    TacomaMike37 [OP] Well-Known Member
    13' DCLB MGM
    For those of you who run their ipod via the auxiliary port. Do you always keep your ipod attached ?
    Trying to figure out a way to maybe run the cable and house the ipod in a hidden location. Leaving an ipod in plain sight seems like an easy target for a thief. Trying to figure out a work around.
    Thanks
  2. Feb 18, 2014 at 12:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get a USA Spec unit and run the connecting cable into the console
  3. Feb 19, 2014 at 11:34 AM
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    I popped out the filler plug next to the port, filed a round notch in the side, and fed the cable from there into the glove compartment. Some day I'll find a black cable instead of the white one and it'll look even less conspicuous.
  4. Feb 20, 2014 at 4:55 AM
    TacomaMike37
    13' DCLB MGM
    This is exactly what I want to do. So this didnt involve you taking the dash off? I'm trying to picture what you did in my mind. I have the empty port right next to the USB/AUX, I can see knocking that out, but not sure what to do next. Do you have any pics of it by chance?
  5. Feb 20, 2014 at 8:39 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Do ipods have Bluetooth connectivity? If so, THIS works great.
  6. Feb 20, 2014 at 11:06 AM
    DRP6833
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    I'm at work now so I can't get any pics. I didn't have to remove anything other than the filler plug. I ended up attaching the cable to a coat hanger wire and pushing it to the hole, then pulling the USB connector through the opening. I also drilled a small hole in the top edge of the glove box and attached the cable with a cable tie.
  7. Feb 20, 2014 at 11:32 AM
    TacomaMike37
    13' DCLB MGM
    Pics would be a huge help to me. I'm kinda a paint by numbers numbskull! The filler plug on mine , it seems I will need to cut it away, its almost like a hard plastic.
  8. Feb 21, 2014 at 6:33 AM
    DRP6833
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Here's a couple pictures of what I did.
  9. Feb 21, 2014 at 6:36 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    '14 Tacos have Ipod intergration?
  10. Feb 21, 2014 at 6:57 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I found that my iPod classic'a battery did not appreciate a year or so of constant charging hooked up to my dock. Thing won't last 20 minutes before going from 100% charge to 0 now. That being said if you have a junker ipod no big deal. I use a new Nano 7th gen I got which had Bluetooth. I just leave it in my jacket pocket or console and as soon as I fire up the taco it connects.
  11. Feb 21, 2014 at 7:48 AM
    rainmn
    rainmn Well-Known Member
    I moved my connector the glove box, since I have an ipod that stays connected to it 100% of the time.
    If you pull out the heater controls, you can easily access the connector in the dash. I connected a USB extension to mine and left it tucked behind the dash. Purchased a switch blank to fill the hole, and ran the USB extension into the glove box.
  12. Feb 21, 2014 at 7:50 AM
    TacomaMike37
    13' DCLB MGM
    Very cool, thx man!
  13. Feb 21, 2014 at 7:51 AM
    TacomaMike37
    13' DCLB MGM
    That an interesting idea as well. How much of a pain was it to remove the heat controls?
  14. Feb 21, 2014 at 8:37 AM
    rainmn
    Takes about 30 seconds....they are only clipped in, no screws. Just be careful not to scratch them in the process.
