Auxillary electrical circuits with a mind of their own?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PDXTac03, Mar 10, 2023.
  1. Mar 10, 2023 at 7:07 AM
    PDXTac03
    PDXTac03 [OP] Member
    Portland OR
    2003 V6 4x4
    The auxillary electric functions come back on after parking. I leave the truck and everything is turned off, and come back and the radio is on.
    I assume its a problem with the ignition key cylinder, or a relay. Would appreciate suggestions from those who may have seen something similar.
    Thanks,
  2. Mar 10, 2023 at 7:23 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    If you're not the original owner of the truck, I would be very weary that a PO may have done something to wire the aux to be always on. It's more common than you might assume. Either way I'd take the trim off and start looking around at the wiring.
  3. Mar 10, 2023 at 7:27 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Without knowing just how things are wired no way to tell the cause of your issue.
    Something is allowing the radio to power up you just need to find the cause.
    i had a truck that turned the day time running lights on at random
  4. Mar 10, 2023 at 7:31 AM
    PDXTac03
    Portland OR
    2003 V6 4x4
    I am the original owner. I did take the dash apart to replace a bulb in the instrument panel, but that was a decade ago, and this behavior just started happening. I never intentionally did anything to cause that circuit to be always on.
  5. Mar 10, 2023 at 9:06 AM
    Bivouac
    You still have the original radio? You return to the truck the radio is powered up playing what you listened to last?
    At any time was an Alarm added? Remote start?
    Rodents chomping wires ? Physical damage in the radio shorting the preset power supply to input power.
    The electrical part of the ignition switch could fail but I have never seen that happen.
    You are able to remove the ignition key from the lock cylinder
  6. Mar 10, 2023 at 9:26 AM
    PDXTac03
    Portland OR
    2003 V6 4x4
    When I bought the truck, I had an aftermarket alarm put on. The FOB was problematic, so I just quit using it. Its been in the circuit unused for at least 10 years. I think this may be the culprit. Does not have remote start though.
    Its the factory radio, and I don't think its a rodent issue. I can't pull the key out of the ignition when its in "ACC" mode. I turn it off all the way, pull the key, and at some later time, it turns back on.
    As I look more into this, I'm thinking I just need to take the unused alarm system out of the picture.
    Andy01DblCabTacoma likes this.
  7. Mar 10, 2023 at 9:52 AM
    Bivouac
    The fact some thing changes to power the radio with the switched power off.
    Is the interesting part just how it is effecting the radio .
    Any paper work with your alarm? Does the Alarm tripping also power up the radio?
    If so just what causes the alarm to trip?
    Good luck I am waiting to hear how this plays out
