Auxillary gas tank?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Samlin, May 9, 2010.
  1. May 9, 2010 at 5:39 PM
    Samlin
    Samlin [OP] New Member
    Silver TacomaTRD
    I'm new to Tacoma ownership and look to y'all for guidance. Is it possible to add another gas tank to my '09 dbl cab TRD? I like long road trips and don't like to stop too often. Any ideas?:eek:
  2. May 9, 2010 at 5:45 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    its def possible, they sell auxillary tanks that mount inside the truck bed, just make sure you have the 4 leaf pack to handle the weight
  3. May 9, 2010 at 5:49 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I'm not aware of any aux tanks that bolt up under the truck but with enough money I'm sure you can get custom tanks built
  4. May 9, 2010 at 9:58 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes it has been done before. It was done by www.ExpeditionsWest.com They put a 22 gallon tank on a 1st gen, right where the spare tire would go.
  5. May 9, 2010 at 10:09 PM
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    I've been thinking about getting one too. I can't list the sites because I never bookedmarked them, but I have found a few sites that have the aux takes that mount under the truck and on in the bed.
    The tanks ranged in size from 20gal upto 40 (if I remember correctly).
    I don't think weight is an issue. I have had my factory tank low to the point that the low fuel light came on, and there was no noticiable difference in my suspention from empty to full. Figure a 21 gallon factory tank, so I put in 18 gal, maybe 18.5 gallons.
    If I,m not misstaken, water weights 7.33lbs per/gallon, and gas is less then that. I'm not sure what gas weights, but if it weighted 7lbs per/gal, then your only looking at 280lbs extra for a 40 gallon aux tank.
    I like the idea of an extra tank. Never want to be stuck out somewhere where there is no gas station. Plus, it's easier to take advanage of lower prices at the pump, and ride out the higher prices when they descide to play the up and down game on us.
  6. Aug 9, 2012 at 9:55 PM
    DARMS
    DARMS Member
    Fairbanks
    12 A-Cab OR
    Better Built makes a 36 gallon "transfer tank" that fits in the bed of my Xtra-Cab Taco in front of the wheel well. I needed to trim the mounting tabs with a die cut, but it works and doesn't take up much room. Along with my regular tank, it gives me a range of 1,200 miles. If you are near an Army base that has a lot of helicopters there is a chance there are butyl rubber fuel blivets. The smallest is 75 gallons and is round so it can be rolled and it has d-rings on either side. Since it's collapsable you can "pressurize" it by sitting on top and "sqeezing" the fuel into your tank. Those should sell for no more than $50. The Better Built cost $316 in Alaska.
  7. Aug 9, 2012 at 9:57 PM
    medic2230
    Murph
    Bama! Roll Tide
    I believe the one that fits in the spare tire spot was from an Isuzu Trooper.
  8. Aug 9, 2012 at 10:29 PM
    RockRescue
    RockRescue Well-Known Member
    Oregon
    2007 TRD Sport
    water weighs 8.35 lbs per gallon:)
