AVEC LED Lighting
Discussion in 'Buy / Sell / Trade' started by mikevee, Jul 16, 2014.
  1. Feb 4, 2015 at 10:12 PM
    #1121
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    Thanks! It wasn't as hard as I was anticipating. Sometimes I look at those wiring diagrams and just see a bunch of scribbles on the page. Haha!
    That's an Air-On-On-Board switch. They have a bunch of different designs and colors. It fits well in the blank spots. I'm sure I'm not the first to have this setup, get the stuff that makes you and your truck happy!
  2. Feb 5, 2015 at 7:04 PM
    #1122
    thai fyter
    thai fyter Well-Known Member
    I took off the grill and lower valence tonight. Not quite sure how you got the light to sit in the lower bumper/valence like you did. Did you use different mounts than the ones that come with the light? I'd prefer to mount it up like you did instead of behind the bumper.
  3. Feb 5, 2015 at 7:08 PM
    #1123
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    You can either make your own bracket or buy a rigid one and modify it a little bit.
  4. Feb 5, 2015 at 8:53 PM
    #1124
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    Gym jamz is right. I used the rigid industries mounts that connect to the bolts that hold the crash bar to the frame. It's a really tight but if you trim a little of the inner corners of the valence plastic you can get it all fit in there. It is tight. I put the mounts in and left everything loose until I had it all where I wanted it and then slowly tightened everything up. The mounts look like this:
  5. Feb 5, 2015 at 9:39 PM
    #1125
    270wsm
    270wsm Well-Known Member
    AZ
    Nice ...
  6. Feb 6, 2015 at 2:19 PM
    #1126
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
  7. Feb 6, 2015 at 5:46 PM
    #1127
    pgthe1
    pgthe1 Well-Known Member
    I got around to installing my 30" optic... This thing is bright!
  8. Feb 6, 2015 at 6:29 PM
    #1128
    mikevee
    mikevee [OP] Well-Known Member
    Socal
    14 prerunner trd offroad
    Looks good!
  9. Feb 7, 2015 at 12:09 PM
    #1129
    mikevee
    Socal
  10. Feb 7, 2015 at 5:43 PM
    #1130
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Got the bar mounted up front and the pods in the back. Those pods are BRIGHT. For floods they have a lot of reach.
  11. Feb 7, 2015 at 5:44 PM
    #1131
    TRSJimmy
    Jimmy
    Gainesville, GA
    Any pics?!
  12. Feb 8, 2015 at 5:46 AM
    #1132
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    so what is the remote harness?
  13. Feb 8, 2015 at 8:44 AM
    #1133
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    the remote is an actual wireless remote. the standard harness is a push button
  14. Feb 8, 2015 at 11:56 AM
    #1134
    mikevee
    Socal
    He's right!
  15. Feb 8, 2015 at 12:24 PM
    #1135
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    For right now the pods are mounted to the bed rail. They rotate to cover both the bed and out the back. I'll experiment with them as far as where to have them and not get them knocked off. Eventually I will add a rack to the shell and they will be mounted on the underside of the roof using the same bolts to hold the rack on. I don't want to drill extra holes in the shell before then.
  16. Feb 8, 2015 at 4:23 PM
    #1136
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Mike,
    Got the package Friday, Thanks bro. Installed the 20 inch optic bar and LED fog lights. Anyone looking for an outstanding product and fast courteous service..... Look no further....... Mike's your guy to get lights..... Hope you get curved bars soon...... Looking to mount on the roof.........
    Before
    After
  17. Feb 8, 2015 at 5:10 PM
    #1137
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Here are the pods at work. The fence is 15 yards from the truck. Not bad for two small flood lights mounted inside the bed with a shell on top. Both pictures are taken at the same setting to give a good idea of just how bright they are. If you notice the two small blue lights over the yellow light on the right in the second picture, those are two road signs being lit up over 100 yards away.
  18. Feb 9, 2015 at 2:32 PM
    #1138
    mikevee
    Socal
  19. Feb 9, 2015 at 2:56 PM
    #1139
    mikevee
    Socal
    Stoked they worked out for you! :)
  20. Feb 9, 2015 at 6:26 PM
    #1140
    pgthe1
    Mike, you have any Optic flush mount pods?(flood)
