AVEC LED Lighting
Discussion in 'Buy / Sell / Trade' started by mikevee, Jul 16, 2014.
  1. Feb 27, 2015 at 3:37 PM
    #1341
    LusoSoccr
    LusoSoccr Well-Known Member
    Matt K
    Western Mass
    2011 Tacoma TxPro DCSB
    Has anyone run these on Zach's Prinsu roof rack? How did the install go? Curious about this as I'm about to add both options this spring
  2. Feb 27, 2015 at 3:59 PM
    #1342
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Working on a mock up of a couple of his bars this weekend hopefully. Can't wait to get one this spring/summer
  3. Feb 27, 2015 at 4:29 PM
    #1343
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    Like flood pattern? if so then yes it does not sure the exact amount but it does.
  4. Feb 27, 2015 at 4:35 PM
    #1344
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Got it mounted then realized it was combo pattern. Took about 30-45 minutes to wire and weld up the mounts.. Hopefully can get an all spot version though to replace this one! Awaiting PM response! :D
  5. Feb 28, 2015 at 9:33 PM
    #1345
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    Ordered up a 40" 4D Optic bar...finally got the install completed the other day...
    Here are some photos!
    Baseline without any lights (headlights/LED Bar)
    Headlight Low Beams
    Headlight High Beams
    LED Bar Only
    LED Bar and Low Beams
    24,000 Lumens is a beautiful thing. My only regret I suppose? I probably should have shelled out a few more bucks to go to a 52" Radius Bar. The 40" light is a combo bar and it is great, but I kinda wish it had more dispersion to the sides. Oh well, here's to a set of flood pods in the near future! (Not to mention I'll be able to wire it to a separate switch to!)
    Thanks again Mike! I look forward to doing business with you again!
  6. Mar 1, 2015 at 11:14 AM
    #1346
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    Say I want to run this off of switched power and not battery, am I correct that a 30" draws 15a? (180w/12v=15amp)
    Thinking of running off an add a fuse.
  7. Mar 1, 2015 at 11:43 AM
    #1347
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    Your math is good. You should run an 18-20 amp fuse.. Depending on tolerances, the resistance of the light bar may be towards the higher side of their tolerances, thus creating a larger power consumption which leads to higher amps.
  8. Mar 1, 2015 at 1:32 PM
    #1348
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    mike, can the C and D buttons on the remote be programmed for anything?
  9. Mar 2, 2015 at 4:24 PM
    #1349
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
  10. Mar 3, 2015 at 9:08 AM
    #1350
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I finally wired my lightbar up using an air on board switch. It was very easy using the supplied harness.
    What I need now are fog lights. My truck did not come with lights. My concern is the mount. Do you have lights that will easily mount in the stock location? There are no fogs there now, so no hardware that I know of. I'm not worried about wiring, just mounting.
  11. Mar 3, 2015 at 9:42 AM
    #1351
    thai fyter
    thai fyter Well-Known Member
    Looks good man, thanks for sharing the pics!
  12. Mar 3, 2015 at 9:48 AM
    #1352
    bbersanti
    bbersanti Well-Known Member
    Ben
    Arvada, CO
    2011 Access TRD Offroad 4.0 V6, 6-spd
    Weathertech's, All-Pro APEX Front Bumper, Maglite seat mount, Fog Light Anytime, Aux Blue Sea Fuse Box, Toyota Bed Mat, color-match grille, 21" LED bumper Light bar, Redline Hood Struts, Full OME 3" Lift
    Does anyone have close-ups of mounting brackets (if any) that come on the smaller pods? I'm trying to figure out if I'll need to buy/fab brackets to mount these as fog replacements in my SOS bumper but the pics don't show the hardware.
  13. Mar 3, 2015 at 10:50 AM
    #1353
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Post 1142 in this thread has a picture of my pods with the supplied brackets. Not a great picture but should give an idea.
  14. Mar 3, 2015 at 11:18 AM
    #1354
    bbersanti
    Ben
    Arvada, CO
    Thanks. I saw these when I was browsing the thread but wasn't sure if those brackets were supplied with the pods or not.
    Mikevee - can you tell me if all the small pods have similar brackets that come with them?
  15. Mar 3, 2015 at 5:17 PM
    #1355
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I figure I'm going to have to fab up some brackets to fit my SOS bumper to replace my fogs. Time to learn to start welding!!
  16. Mar 4, 2015 at 5:24 AM
    #1356
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mike, are your Optic series lights and regular lights the same body? Like is the body of the 30" optic the same as the regular? I think you could probably guess where I'm going with this one :D
  17. Mar 4, 2015 at 8:36 AM
    #1357
    mikevee
    mikevee [OP] Well-Known Member
    Socal
    14 prerunner trd offroad
    Same dimensions, different brackets ;)
  18. Mar 4, 2015 at 8:36 AM
    #1358
    mikevee
    Socal
    Depends which pods good sir.
  19. Mar 4, 2015 at 10:23 AM
    #1359
    bbersanti
    Ben
    Arvada, CO
    I'm looking for lights to fill a 3.5" round fog light cutout. What do you have that would work here and what kind of brackets do they have?
  20. Mar 4, 2015 at 11:10 AM
    #1360
    03 TERMINATOR
    03 TERMINATOR Member
    Gregg
    Washington
    17 Tacoma Pro Super White
    17X9 Fuel Mavericks with 265/70/17 BFG KO2
    Mike, What is the difference between the CR series and the SLD2 Series? I have a 13 sport and am thinking of getting one of your 30" bars and a N-Fab T12300RL bar. Will either of these bolt up to the N-fab?
