AVEC LED Lighting
Discussion in 'Buy / Sell / Trade' started by mikevee, Jul 16, 2014.
  1. Mar 18, 2015 at 4:08 PM
    #1401
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    just missing the fogs now :D
  2. Mar 18, 2015 at 4:38 PM
    #1402
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    :drool:
  3. Mar 18, 2015 at 6:17 PM
    #1403
    ThomasMore66
    Dallas/Fort Worth & Durango
    What bumper is that? I like it.
  4. Mar 18, 2015 at 6:45 PM
    #1404
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Look at the very bottom of it.
  5. Mar 18, 2015 at 9:03 PM
    #1405
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    its a pelfreybilt
  6. Mar 18, 2015 at 9:07 PM
    #1406
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Finally got around to wiring these!
  7. Mar 18, 2015 at 9:12 PM
    #1407
    ThomasMore66
    I thought they would only hold a single row. Aluminum or steel?
  8. Mar 18, 2015 at 9:13 PM
    #1408
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    That is a great idea. I need to do this now
  9. Mar 18, 2015 at 10:17 PM
    #1409
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I was the first to request/show to Tyler that a double row would fit. I stand by that dude no matter what. I asked for a bunch of custom stuff to fit me cheap Chinese lights on there, and the day I was supposed to pick up, he called me to let me know it was going to be a little bit more because he was custom fabbing up stuff to get the job done right and PelfreyBilt Quality. He told me, and I quote "I would rather lose money doing it right and making sure it was high quality, than put out crap".
    So anyhoo, yea far as i remember, the single row and double rigid lights will fit in that spot...I think Tyler has kept the same cutout, but it may have gotten smaller...just give him a call and ask about it and he can confirm if you can still fit a double row in there or not :D
  10. Mar 18, 2015 at 10:32 PM
    #1410
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    its a steel bumper, it has brackets for the single row. The double row is little too wide for the brackets so i bent/hammered them until it fit.
  11. Mar 19, 2015 at 4:07 AM
    #1411
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Thanks for the pics!!
    I am thinking about doing this to mine! What brackets did you use? Looks really good!!
  12. Mar 19, 2015 at 9:33 AM
    #1412
    mikevee
    mikevee [OP] Well-Known Member
    Socal
    14 prerunner trd offroad
    Looks good!
  13. Mar 19, 2015 at 9:35 AM
    #1413
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I used CBI Off-road brackets. I really like them!
  14. Mar 19, 2015 at 12:49 PM
    #1414
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    Thanks to the help of gym_jamz, I was able to get this thing mounted.
  15. Mar 19, 2015 at 1:09 PM
    #1415
    TRSJimmy
    Jimmy
    Gainesville, GA
    :woot: Looks good! I'm glad it worked out
  16. Mar 19, 2015 at 1:11 PM
    #1416
    ThomasMore66
    Did you ever ponder putting it behind the bottom grill? I like that look, but I'm a little leery of having things where sticky fingers can get them. I live in Dallas.
  17. Mar 19, 2015 at 1:19 PM
    #1417
    clarkie152
    MA
    2016 4Runner Trail
    I did ponder behind the bottom grille. I saw some comparisons of the light output that some guys have behind vs. in front. If it is behind, you really hinder the output as itll reflect off the grill and bumper. I only like doing things once.
  18. Mar 19, 2015 at 1:54 PM
    #1418
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    will the ( 30"("") 16400 lm - 210.00 ) mount to a 2012 w/ the Rigid Industries mounts?
  19. Mar 19, 2015 at 1:55 PM
    #1419
    mikevee
    Socal
    yes
  20. Mar 19, 2015 at 1:55 PM
    #1420
    Manwithoutaplan
    ID
