Average MPG?
Discussion in '1st Gen. Tacomas (1995-2004)' started by El_Best_Hamon79, Oct 5, 2022.
  1. Oct 5, 2022 at 3:01 PM
    El_Best_Hamon79
    El_Best_Hamon79 [OP] Well-Known Member
    Abraham
    04’ Tacoma Prerunner
    Rear bed lights
    I drive a v6 04 prerunner and I'm getting about 15mpg with my soft top bed cover. When I didn't have it, I was getting about 13mpg. Is that normal or average? If not, what can I do to help it? I do want to run an engine cleaner for like carb build up and such. Do you guys think it's a good idea to run a cleaner?
  2. Oct 5, 2022 at 3:14 PM
    coopnugz
    coopnugz Well-Known Member
    Cooper
    2022 Black Trail
    It depends on driving style but that seems pretty low. Are you pretty heavy on the throttle in daily driving? If you suspect carbon build up you can try some seafoam in the tank or better yet take off the throttle body and clean it up real good and clean the mass airflow sensor with a dedicated MAF cleaner.
    I did that when I changed my spark plugs last and while it didn’t make a huge difference because everything was already fairly clean, my 04 v6 4x4 gets 19-21mpg with a fiberglass shell, roof racks, 2.5” lift and all terrain tires. 13-15mpg for a prerunner seems low…
    I do drive like a grandma though.
    JustJon, hp415 and loudboy like this.
  3. Oct 5, 2022 at 3:48 PM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    it does. i've had some recent work done (new injectors, etc.) but i'm getting 15mpg on my 02 4x4 DC while towing a small offroad trailer that isn't exactly aerodynamic.
    i'd check all the usual stuff, fuel filter, sparkplugs, etc.
  4. Oct 5, 2022 at 3:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is the check engine light on?
  5. Oct 5, 2022 at 6:49 PM
    loudboy
    loudboy Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    Basics first - Check tire pressure, replace air filter, replace fuel filter, clean throttle body/MAF, check spark plug wires and spark plugs, run some Seafoam through the system.
    CrustyTaco likes this.
  6. Oct 5, 2022 at 7:05 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    I'm getting 16-18mpg in mixed driving, can get low 20s with 100% interstate miles. loudboy's list is a good place to start, also if you have larger tires than stock you'll need to adjust your mileage to get an accurate measurement. Can use a calculator like this: I have 235/85r16 tires, so my adjustment is 3.7%
  7. Oct 5, 2022 at 7:45 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Similar situation with my ‘03 base cab 2.4L manual. Around 16 mpg mixed driving (a lot better highway only). Doesn’t burn any oil, standard tires inflated. All the other little things like plugs, injectors cleaned, MAV cleaned, air filter always clean. Don’t have the money to have someone diagnose sensors. Idles nice. Some say you just hit a lower MPG after 116k and accept it. I’d be stoked just to get 18 MPG (with gas prices now). Not gonna spend hundreds trying to get that, tho (possibly without success).
  8. Oct 5, 2022 at 7:58 PM
    LiftedOn35s
    LiftedOn35s Graduated!
    Noah
    Northeast FL
    Shadow Grey Met. 2004 Tacoma V6 5MT TRD OR
    1" level, 16" American Racing wheels, 32" M/Ts
    My '04 3.4 5-speed 4x4 gets 14-16 around town/90% city driving (
    Highway gets me 20mpg with the a/c off, windows up, and cruise at 60-65mph
    32" E load range (62lbs/per) mud tires and a fresh tune up (plugs, oil change, MAF clean, fresh air filter)
    The tune-up is probably your best place to start
  9. Oct 5, 2022 at 8:53 PM
    Caslon
    Mine probably gets that too, all freeway. City driving really cuts down my overall MPG. (Heh, no duh).
  10. Oct 5, 2022 at 10:41 PM
    hp415
    hp415 Well-Known Member
    Paul
    1999 excab taco v6 TRD 5spd
    Hilly city driving I’m at 14-17, highway at 18-21 in 99 4wd taco 3.4 manual 226k with 3” lift, 265/75/16s, ARB bumper with steel lined winch, fiberglass topper and sleeping platform that must weigh >300lbs. Being easy with acceleration and thoughtful early braking + keeping it at 70mph or below helps a lot.
  11. Oct 5, 2022 at 10:53 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    My '98 2.7L manual gets 20mpg. Highway, urban, stop and go, drive slow, drive hard, it always gets within a few tenths of 20mpgs.
  12. Oct 5, 2022 at 11:27 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    reg cab 4x4 auto 16 city, 17hwy
  13. Oct 6, 2022 at 4:03 AM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
    My ‘02 gets 18-20 pretty consistently with mixed driving.
    Start with list above and ease up on the throttle maybe?
  14. Oct 6, 2022 at 6:23 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Not Milage related, but do you know when the Lower Ball Joints were last replaced. Did this truck have a good maintenance history with it.
    Back to milage stuff. My 03 DC 3.4L was getting around 15 mpg. I threw a misfire code and replaced all the plugs and wires with a new air filter. I'd already cleaned the throttle body and MAF. After the new plugs and wires, I'm backup to around 18 average and 21-23 on the highway. Good Luck and a Nice looking truck.
    coopnugz likes this.
  15. Oct 6, 2022 at 6:38 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    Sounds pretty low to me. I’m getting about 18-19 with my 2” lift, 33s and 4.56 gears, V6 manual. Are your tires oversized with stock gearing? I know when I had 3.91 gears and 33s I was getting 13-14mpg
  16. Oct 6, 2022 at 6:44 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    My 02 totally stock extended cab with 500K miles still gets 22 mpg on the highway
  17. Oct 6, 2022 at 6:54 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That seems low to me too.
    My supercharged 04 V6 access cab 4x4 on 33” mud terrains and steel wheels and weighs 5800 pounds gets 14.5mpg
  18. Oct 6, 2022 at 12:40 PM
    Phessor
    Phessor Well-Known Member
    17 MPH on pavement and 10 MPH on long dirt excursions.
    otis24 and coopnugz like this.
  19. Oct 6, 2022 at 1:08 PM
    El_Best_Hamon79
    Abraham
    Rear bed lights
    No check engine light. I have done the spark plugs and wires not to long ago, how often do they need to be changed?
  20. Oct 6, 2022 at 1:24 PM
    El_Best_Hamon79
    Abraham
    Rear bed lights
    I have a k&n air filter in it. And aren't injectors expensive? I think I'm going to clean the MAF and stuff like that and run seafoam before I take it to get done by someone else.
