AVH X5800BHS FTW!
Discussion in 'Audio & Video' started by SCFirefighter, Aug 2, 2016.
  1. Feb 5, 2017 at 5:21 AM
    #41
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    Yea should be for steering wheel controls
    voz likes this.
  2. Feb 5, 2017 at 6:21 AM
    #42
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    But, my steering wheel controls will still work, right?
  3. Feb 5, 2017 at 6:33 AM
    #43
    voz
    VOZ
    VOZLAND
    The Clean One
    Do I use rca connector from crux harness or sub inputs on back of head unit?
  4. Feb 5, 2017 at 6:46 AM
    #44
    voz
    VOZ
    VOZLAND
    The Clean One
  5. Feb 5, 2017 at 7:28 AM
    #45
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    Did your truck have factory satellite radio?
    If I remember correctly I had some unused connections as well.
    Your steering wheel controls will work. It should have been sent to you with the little switches on the box in the correct order.
    What rca are you talking about?
  6. Feb 5, 2017 at 7:37 AM
    #46
    voz
    VOZ
    VOZLAND
    The Clean One
    Crux Swrty61s harness has a set of rca's.. I am also hooking up a amp and subs, unsure wether to use rca on back of head unit or ones with the above mentioned harness....
    Yes I have satellite
  7. Feb 5, 2017 at 7:40 AM
    #47
    jamiec
    Jamie
    Chillicothe, Ohio
    Oh I see.
    The rca's on the crux should be for your backup camera?
    You will need to use the rca's from the amp to the preout on radio.
    Don't forget to mount your Bluetooth mic. I put everything back together and realized I forgot it so I had to take it apart again.
  8. Feb 5, 2017 at 7:47 AM
    #48
    voz
    VOZ
    VOZLAND
    The Clean One
    The crux harness won't incorporate factory Mic? If not, dude at crutchfield lied to me...
  9. Feb 5, 2017 at 7:52 AM
    #49
    jamiec
    Jamie
    Chillicothe, Ohio
    No it didn't work for me.
    I clipped mine to the headliner by the mirror and ran the wire down the A pillar then to the radio. You won't notice it up there really.
  10. Feb 5, 2017 at 8:09 AM
    #50
    voz
    VOZ
    VOZLAND
    The Clean One
    Ten four,
    I have to run hardwire kit for my dash cam anyways, run them both...
    jamiec[QUOTED] likes this.
  11. Feb 5, 2017 at 8:15 AM
    #51
    voz
    VOZ
    VOZLAND
    The Clean One
    Everything seems fine, but no steering wheel controls... Sounds so much better, and I haven't messed with eq settings
  12. Feb 5, 2017 at 8:16 AM
    #52
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  13. Feb 5, 2017 at 8:18 AM
    #53
    voz
    VOZ
    VOZLAND
    The Clean One
  14. Feb 5, 2017 at 8:24 AM
    #54
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    if I remember correctly, the adapter for the steering wheel controls has a red and white RCA, I actually had to buy and adapter that goes fom RCA to 3.5mm headphone jack and plug it into the Remote plug on the back of my pioneer
  15. Feb 5, 2017 at 8:29 AM
    #55
    jamiec
    Jamie
    Chillicothe, Ohio
    Mine doesn't work like it did factory.
    Up/down does both track skip and fast forward/rewind. Center button and left right does nothing.
    The end call button ends calls. Talk button does nothing.
    The voice button when held down activates Siri and if you just tap it, it turns the volume down
  16. Feb 5, 2017 at 8:34 AM
    #56
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    its because the steering wheel control adapter. there are some out there that will allow everything to work properly. I was reading up on this in a thread about people who have earlier gen 2's with no right hand steering wheel controls and wanted to add it, like I will be doing. This one is suppose to allow all functions
    http://www.pac-audio.com/productDetails.aspx?ProductId=1016&CategoryID=29
  17. Feb 5, 2017 at 8:37 AM
    #57
    jamiec
    Jamie
    Chillicothe, Ohio
    I saw the PAC adapter but I didn't want to mess with it again. Mine does what I need it to
    Bocsy44[QUOTED] likes this.
  18. Feb 5, 2017 at 8:40 AM
    #58
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    yeah I think I'm going to get it, I don't have the right hand controls but it would be nice too. I have to pull everything out anyways because I forgot to ground the parking brake wire lol so I cant update my firmware or delete by BT connection history.
  19. Feb 5, 2017 at 8:52 AM
    #59
    jamiec
    Jamie
    Chillicothe, Ohio
    I tried to update my firmware once but it wouldn't work. I used the factory USB when I hooked it up and I think that is the problem. I believe I'll need to use the actual USB cable that the radio came with for the update.
  20. Feb 5, 2017 at 9:04 AM
    #60
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    its possible. I think it would depend on how the factory usb is connected to the HU, when you plug your phone into the factory usb does it connect to the HU? or does it only charge the phone?
