Aviation BS and Photo Thread
Discussion in 'Off-Topic Discussion' started by JB, Feb 26, 2016.
  1. May 24, 2021 at 9:32 AM
    #9841
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    Playing in the pattern at PWM :cookiemonster:
    B1CB50CB-F82F-4FF9-BD13-7436C275D0BA.jpg 9E107909-B4B3-4572-AD5D-1EB5B53CB531.jpg
    99kx250, Hardscrabble, Sig45 and 6 others like this.
  2. May 24, 2021 at 10:54 AM
    #9842
    kamakazie_1
    kamakazie_1 Well-Known Member
    RJ
    Mims, Florida
    2012 White Tacoma DCSB TRD OR 4X4
    Factory Roof Racks Installed, Vent Visors, Meso dome and maps, Stubby Ant., 265/70-16 Discovery RTX, Dasaita 9" Android HU, RedLine Hood Supports, MBRP Cat Back Stainless Exhaust
    Well, just thought I'd leave this here... LOL
    RJ
  3. May 26, 2021 at 11:57 AM
    #9843
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
  4. May 26, 2021 at 12:03 PM
    #9844
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    KOBE!
  5. May 26, 2021 at 12:05 PM
    #9845
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Reminds of what my instructor used to say about emergencies at night when we were flying around Prescott and it was dark as hell, "when you think you're getting close to the ground turn on your landing light. If you like what you see leave it on. If you don't turn it off...."
  6. May 26, 2021 at 12:08 PM
    #9846
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Rock chips while flying are usually a bad sign as well.
  7. May 26, 2021 at 12:21 PM
    #9847
    Gunshot-6A
    Conner
    Everett, WA
    Reminds me of a story my dad told me from his HH-3 days in the Phillipines:
    Doing night time air refueling practice off a C-130 in a valley with higher elevation peaks on both sides, gas up successfully, separate and turn to fly to another practice area.
    C-130 very shortly after takes a massive hit from a mid-air collision with ???, no other aircraft are visually identified, base radar cant see anything, helos get called back to the area for SAR, do a bunch of patterns in the valley, no joy and RTB. Inspection finds sheet metal damage and all the paint just below the nose of the C-130 is scraped off.
    Next morning, SAR resumes for unknown aircraft in the area of the hit. No joy again. As they go to climb out of the valley and RTB again, crew chief catches a glimpse of something out of his eye.
    The locals had run a bunch of thick steel cables off the peaks for illegal logging operations :eek: The herc had hit one of the cables *just* low enough that it bent around the nose and only took the paint with it.
    FlyinRyan893, CurtB, ETAV8R and 2 others like this.
  8. May 27, 2021 at 8:22 AM
    #9848
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
    Search Google images "Far Side airplane" for a bunch more.
  9. May 27, 2021 at 8:23 AM
    #9849
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    MatthewMay1 and JB[OP] like this.
  10. May 28, 2021 at 11:28 PM
    #9850
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Oh hey! That's in my neck of the woods! I train out of AUG but fly thru PWM and SFM often. Love working with portland ATC, they're so nice and helpful. They let me romp around the city at night a while back when the airspace was dead quiet. Then cleared me for unrestricted climb in the Sundowner :D
    Fly safe, see ya around:cheers:
  11. May 29, 2021 at 3:18 AM
    #9851
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    Yeah Portland atc is super chill and easy to deal with (aside from the woman on tower freq that eats her mic on occasion that I have to constantly ask to say again)
    I actually flew down to Sanford yesterday to grab a Montreal chart. Im heading up to Augusta and Bangor next week.
    :fistbump:
    risethewake[QUOTED] likes this.
  12. May 29, 2021 at 4:31 AM
    #9852
    risethewake
    Will
    '15 MGM Sport AC
    Nice, I love swinging by Pilots Cove. Bgr is just as awesome, especially watching all the military birds coming through. I fly outta there a bunch too, in the club's 152. Makes me feel like a mosquito on that 11000'x200' runway haha.
  13. May 31, 2021 at 3:00 PM
    #9853
    BackOff
    BackOff Well-Known Member
    Derek
    The corner of Idiocracy and the Twilight Zone
    2004 SR5 4Runner V6 4x4
    Noise mods/Weight Mods
    What are these Battlestar Galactica looking space fighters?
    Mojave north of Edwards...Google Earth...
  14. May 31, 2021 at 3:03 PM
    #9854
    BackOff
    Derek
    And check out...Moses Lake
    SOSHeloPilot likes this.
  15. May 31, 2021 at 3:05 PM
    #9855
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Look like Saab Drakens
  16. May 31, 2021 at 3:35 PM
    #9856
    BackOff
    Derek
    I think your right.
    Couple more Edwards AFB.
    Would be so cool to walk around... or even fly over.
    /salute
    Tallgrass05 likes this.
  17. May 31, 2021 at 3:45 PM
    #9857
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    What is above the Hurc? Looks like a bronco but the second wing is throwing me off.
  18. May 31, 2021 at 3:50 PM
    #9858
    BackOff
    Derek
    I was liking the looks of that top right plane...tiny jet 4 engines and tanks on the wings.
    Unrelated...
    Was a Gulfstream G650
    ...671mph on a southbound flight...dammmmmm
    GLF6
  19. May 31, 2021 at 3:54 PM
    #9859
    CaptAmerica
    Cap
    Saab Drakkens. The C-130 looks like they’ve already started parting it out to fix the remaining E-models in the ANG fleet.
  20. May 31, 2021 at 3:58 PM
    #9860
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Isn't that one of Burt Rutan's designs? Reminds me of Spaceship One.
    Gunshot-6A likes this.
