AVIC-Z1 Install
Discussion in 'Audio & Video' started by Avarice, Nov 30, 2006.
  1. Nov 30, 2006 at 5:29 PM
    Avarice
    Avarice [OP] New Member
    I have posted this on some other toyota related sites, but haven't really gotten the kinds of answers I need, so I thought I would try here and see if I get any better results.
    I recently installed the Pioneer AVIC-Z1 navigation unit in my 2004 Tacoma Double Cab. I haven't done a stereo install since my high school days and this took me most of my turkey holiday :D.
    I have everything connected except 3 wires. Two of the wires (speed & reverse) aren't strictly necessary for operation of the unit, but they make the nav more accurate in cases where it cannot get a good satellite signal (underground, etc). The last wire (parking break) is necessary for most of the nav & configuration functions to be operational.
    Here are the wires I need to find out where they go:
    Speed Signal Input (pink wire)
    Reverse Gear Signal Input (violet/white wire)
    Parking Break - Power supply side (light green wire)
    I need diagrams, pictures, or very very good descriptions of where I can find the connections I need to make. If you could help me, I would really appreciate it.
    Thanks!
    Brandon
  2. Nov 30, 2006 at 5:34 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  3. Nov 30, 2006 at 9:44 PM
    Avarice
    I don't really know how to read these manuals, but I will give it a shot. Thanks for your help, I have something to go on now.
    Brandon
  4. Nov 30, 2006 at 10:01 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
  5. Jan 9, 2007 at 12:26 AM
    darrellabaker
    darrellabaker New Member
    Thanks for the link!!! I just completed my AVIC-D1 install thanks to you, Banshee!!
  6. Jan 9, 2007 at 10:11 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Glad to help out! :thumbsup:
  7. Jan 10, 2007 at 8:05 PM
    sunruner19
    sunruner19 Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
    For those that are installing a avic z1 in '05 to '07, here is some helpful info that i got from pb for the parking brake wire, reverse wire, and speed sensor wire connections with pics
    http://www.toyotanation.com/forum/t138609.html
  8. Jan 10, 2007 at 10:01 PM
    darrellabaker
    Thanks sunruner19
  9. Jul 31, 2007 at 12:44 PM
    ScottTRD
    ScottTRD Well-Known Member
    NC
    2016 Limited DCSB 4x4 Auto
    I have a 07 Tacoma 4x4 Sport and hooked the wire to the same one shown in the post (pink and white wire with insulation cut off) and I get no speed pulses. Is the speed wire different in the 07s? I am hooking up a AVIC-D3.
  10. Jul 31, 2007 at 2:05 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    check out avic411they have tons of info on the n's, z's, d's, and other pioneer products including the bluetooth, xm, sirius...etc
  11. Jul 31, 2007 at 4:13 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    Wrong wire, it should be purple/ white.
    Location is second plug from bottom, #8 cavatity is a purple wire which is the speed sensor.
    wire code is the same for 05 thru 07 regardless of body style or engine tranny config.
  12. Aug 1, 2007 at 7:06 AM
    ScottTRD
    NC
    I found it. Don't know how I got thinking it was a pink and white wire.
  13. Aug 1, 2007 at 2:35 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    Glad to hear that you found it. Was hoping that pic helped also. My problem is that I am color blind and had to get someone to pick the right wire for me, lol.
  14. Dec 22, 2007 at 9:39 AM
    captainsav
    captainsav New Member
    Any suggestions would be very much appreciated... checked all connections, can't get power...
  15. Dec 22, 2007 at 10:35 AM
    sunruner19
    Bill
    09 Tacoma 4WD
    First thing to check is the fuse under the hood. For some reason, this can pop when changing radios. Are you using adapter cables between radio and original radio connectors or did you splice directly into original radio harness?
  16. Dec 22, 2007 at 10:53 AM
    captainsav
    So there is a fuse in abox under the hood? I will explore that ASAP... I am currently spliced directly in, using some wiring diagrams I found through this site...
  17. Dec 22, 2007 at 12:08 PM
    captainsav
    That was it, my friend... thanks so much for your help... I didn't find any other reference to that fuse in my searches. Have a great holiday
  18. Dec 22, 2007 at 12:44 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    glad to be of help on this. I myself blew that fuse when I installed my avec-z1
    Are you subscribed to the real traffic reports? I left a few links as far as wiring photos in this thread earlier. Its a great system. Dont use any alcohol based window cleaners on the screen and definetly use a micro towel with the radio off.
