Avid Bolt On Sliders Installed/Review
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pearcem87, Jul 4, 2013.
  1. Jul 4, 2013 at 12:48 PM
    Pearcem87
    Pearcem87 [OP] Well-Known Member
    2013 TRD Off Road
    Well, I got my bolt on sliders from Avid yesterday. The customer service was fantastic, and it took between 3-4 weeks from order to delivery. The overall quality of the product is great, and all the welds are clean. As far as install goes, these use the six bolt holes on the body for step bars or running bars. They are not real sliders since they do not connect to the frame, but they are made out of the same material the weld-on sliders are built out of. All you have to do is take out the little plastic plugs, line up the sliders, and bolt them in with the included stainless bolts and washers. Took about 10-15 minutes to do them both. Everything lined up well, and there were not fit/alignment issues.
    For coating, I used duplicolor spray on bedliner, after priming. As you can see, my paint job is far from perfect, but I had to paint indoors, and don't have a large space like a garage. All in all, it still turned out fairly well, and gave me the textured look with a non-skid finish.
  2. Jul 4, 2013 at 12:55 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Might want to change your thread so it says that they are not sliders. Some people might get the wrong impression that these are sliders.
  3. Jul 4, 2013 at 1:00 PM
    KnoxTac0713
    KnoxTac0713 Well-Known Member
    Justin
    Knoxville, TN
    13 DCSB SR5 4x4 Barcelona Red
    Bilstein 6112, rear 2.0 Icon VS shocks, TRD Black SEMA wheels, 255/80/17 Cooper ST Maxx, SOS Rear bumper, SOS bolt on sliders,TRD skid plate, derped badges, 15% tint, color matched oem grille, lamin-x amber fog covers, TRD cat-back exhaust, Tacoma bed mat, Tonno-pro trifold, Depo black tail lights, front tow hook w/ D shackle, Wheeler's Superbumps rear, Wheeler's 1 inch block rear, Custom Car Grills mesh grill insert, light bar in lower valence
    Looks good man. Thanks for posting. I'm looking forward to getting this exact product for my truck. And since Avid sells them as "bolt on sliders" I don't see why you would change the title of your post.
  4. Jul 4, 2013 at 1:01 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    That is what Avid markets the name of the product as. I understand your point completely, but Avid has a separate product marketed with the name "steps."
  5. Jul 4, 2013 at 1:10 PM
    Pearcem87
    2013 TRD Off Road
    I see your point, but I put the name that way since that is how the product is listed on Avid's site. In case there is any misconception, they are not real sliders, since they do not attach to the frame. They look like sliders, and are more robust than most normal step bars, but do not hang down as low. Good alternative to the regular step bars for someone that wants a little more protection and better clearance, but does not need real sliders that can support the weight of the vehicle or act as a high lift point.
  6. Jul 4, 2013 at 1:33 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    That's a bit shady on Avid's part. Well hopefully anybody doing research on these stumbles upon this post so they are not trying to buy these with the intent of using them as real sliders.
  7. Jul 4, 2013 at 1:39 PM
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
    What did you use for primer? They look great.
  8. Jul 4, 2013 at 1:41 PM
    CanisLupus
    Stokesdale | NC
    In the product description, they state something along the lines of "...they mount to the factory running board locations and are meant to look like sliders for those who want the offroad look without the true function of sliders."
    I actually ordered my sliders as the bolt-on (I thought some bolts into the frame, like other vendor's bolt on versions, would be strong enough for what I wanted) until I re-read the "factory running board mount location" and just changed to weld-on. Much happier knowing I can use my sliders without worry.
  9. Jul 4, 2013 at 1:43 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    On the Avid web site it states the bolt on "sliders" are not meant for hard core offroading and that they are really just step bars. Bellow is a copy from Avids website.
    The bolt-on slider/steps are an alternative to the step bars. They are designed more for the people that like the looks of sliders but don’t need the super strength of weld ons. There is no drilling or welding required to install them. They simply bolt into the factory running board mounts. Because of the mounting location, these sliders are not intended to support the weight of the truck but can be used as steps, dent protection, and light off-roading. Think of them as step bars that look like sliders.
    I have their weld on sliders and they paid for themselves in 2 weeks after having them. Great Company to deal with.
  10. Jul 4, 2013 at 2:26 PM
    Pearcem87
    2013 TRD Off Road
    "These sliders are not intended to support the weight of the truck but can be used as steps, dent protection, and light off-roading.". That is exactly what I was looking for. Most of my off road use is access roads for hunting, fishing and camping, and the occasional easier trail for recreational off roading. I wanted a little bit of added protection to the door sill area for stumps and small trees on tighter trails, but I won't be doing anything that justifies real sliders for at least a few years. I did not buy them under the impression that they were actual sliders that attached to the frame.
  11. Jul 4, 2013 at 2:32 PM
    TooSense
    TooSense Active Member
    Las Vegas
    07 DCSB Impulse Red Pearl
    i am not as familiar with this type of stuff but i do not off road and want to purchase something that assists getting in and out the vehicle and prevents people from door dinging me. would i be looking for sliders or something like this?
    be nice everyone thanks
  12. Jul 4, 2013 at 2:34 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    I understand what you guys are saying but your average person won't read the fine print. Look how many threads a week come up about the 4wd indicator light beeping. People just won't take the time to read the manual.
  13. Jul 4, 2013 at 2:55 PM
    Pearcem87
    2013 TRD Off Road
    Haha well put. I think you have summed up the majority of the human race. As to the other questions:
    Goose8651: I used a basic primer I picked up at autozone. It was actually right beside the bed liner stuff. It's called "prep-all", and made by Klean-strip. One good coat, let it sight for a couple of minutes, a good wipe down with a detailing cloth, and I was all set.
    Toosense: This product sounds like it would fit what you are looking for, but it does not drop down very low. Avid (among others) also make step bars that serve the same function with regards to protecting the door from dings. I am not sure if they come out as far away from the body, but they do hang down lower, and all of them have designated drops for footholds. They are also usually made of lighter materials. The portion of mine that is visible is made of the same tubing as that portion Avid's weld on sliders, and is heavier steel than many of the step bars that are available.
  14. Jul 4, 2013 at 3:10 PM
    Goose8651
    DFW
    2013 Double Cab
    Thanks. I bought a set from Streetacos and been.looking into either linex'ing them, or go your route.
  15. Jul 4, 2013 at 3:18 PM
    Pearcem87
    2013 TRD Off Road
    No problem. A lot of the other threads on here discussed issues with any slider coating chipping. Mud flaps should help this a lot, but if you are actually putting your sliders to good use, I don't know how line-x will hold up. By doing it this way, I can easily touch up, and pick up a can in most auto parts stores for about $10, but I still get the bed liner look and texture. I cannot speak from experience how line-x or rhino (or any other professional liner) would hold up if you put the weight of the ruck on them on a rock, log, etc. Good luck!
  16. Jul 4, 2013 at 3:23 PM
    Goose8651
    DFW
    2013 Double Cab
    How many cans of the Bedliner paint did you use?
  17. Jul 4, 2013 at 4:05 PM
    TooSense
    Las Vegas
    alright thanks im glad you posted this because i see others and dont have the eye to tell the difference.
  18. Jul 4, 2013 at 4:44 PM
    Pearcem87
    2013 TRD Off Road
    It can be done with 2, but I used about 2.5. Once I moved the sliders outside and got them mounted, I saw some spots that I missed, rough spots where drips hardened, etc. So I basically used the last 1/2 of a can to touch up, and do an extra heavy layer on the areas where people will be stepping.
  19. Jul 4, 2013 at 7:16 PM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Silly question alert.....
    ...If one bought Avid bolt on sliders, and then a few years later realized they needed real sliders, could they just have the sliders welded on OR are they completely different?
    Thanks
  20. Jul 4, 2013 at 7:47 PM
    CanisLupus
    Stokesdale | NC
    Avid sells their legs unattached for the weld-on so that the customer can choose their desired angle, so yes, I believe the mounting process is very different. I had to have the shop weld the legs on to the slider at the angle I wanted, then the slider onto the truck.
