Avid bolt on sliders
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Friedtacolover, Sep 18, 2017.
  1. Sep 18, 2017 at 8:51 PM
    Friedtacolover
    Friedtacolover [OP] Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    SOLD .......SOLD
  2. Sep 18, 2017 at 8:55 PM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    I just ordered a set from SOS Concepts and have been considering getting them Line-X'd before I put them on. How much did you have to pay for the Line-X job? Your price seems like a steal for some lucky person.
  3. Sep 18, 2017 at 9:00 PM
    Friedtacolover
    Travis
    Ontario, Ca
    350$ was worth it you wont regret it
  4. Sep 18, 2017 at 9:10 PM
    Friedtacolover
    Travis
    Ontario, Ca
    What you pay for them i need short bed sliders now
  5. Sep 18, 2017 at 9:15 PM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    These are more side steps not sliders for those looking for protection.
    tcjacado and freddy2923 like this.
  6. Sep 18, 2017 at 9:17 PM
    Friedtacolover
    Travis
    Ontario, Ca
    Then why does AVID outdoors a respected company sell them as sliders? I get your point weld on is better but pleanty run these. AVID would argue different
  7. Sep 18, 2017 at 9:19 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Sliders are supposed to take impacts. The holes that these mount to on the body of the truck can't hold up to the same force that the sliders that bolt on to the frame can.
    tcjacado likes this.
  8. Sep 18, 2017 at 9:42 PM
    pngo121
    Phi
    Pittsburg, CA
    That thing couldn't hold a hit of a small rock. True bolt on sliders bolt to frame of truck. Bolting onto stock location of side steps does absolutely nothing.
  9. Sep 18, 2017 at 10:56 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I recently installed these with the stand offs from avid. The weld on and these are the same product. Only difference is that these bolt to the rocker panel. Yes these are not meant to take impact, but you can cut the bolt on brackets off and weld on the standoffs. Then they become trail ready rock sliders.
  10. Sep 18, 2017 at 11:03 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    The frame mount kit will set these up nice. A solid hit to these as is will do some damage though.
  11. Sep 18, 2017 at 11:06 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Agreed. I highly suggest to get them welded before any wheeling. I had them bolted to the rocker panel for a week or so and they're very handy just as a step as well. I would use the kick out as a step to get to the back end of my roof rack.
  12. Sep 18, 2017 at 11:18 PM
    pngo121
    Phi
    Pittsburg, CA
    if you cant jack from them, they arent sliders of any sort. i bet if you asked avid, they would say they wouldnt recommend it.
  13. Sep 18, 2017 at 11:22 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I've lifted my truck off the ground to test, with my farm jack, several times. They weight about 60-70lbs a piece. The brackets are directly from avid.
  14. Sep 18, 2017 at 11:26 PM
    pngo121
    Phi
    Pittsburg, CA
    Quoted from the Avid page
    The bolt-on slider/steps are an alternative to the step bars. They are designed more for the people that like the looks of sliders but don't need the super strength of weld ons. We understand that some people don't want to weld to their frame or drill a bunch of holes in it to get strength that they don't need. There is no drilling or welding required to install our bolt on version. They simply bolt into the factory running board mounts. Because of the mounting location, these sliders are not intended to support the weight of the truck but can be used as steps, dent protection, and light off-roading.
  15. Sep 18, 2017 at 11:27 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I think he is saying he has done that since doing the weld on modification kit from avid.
    Thyces likes this.
  16. Sep 18, 2017 at 11:28 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Read
    tacotroy17 likes this.
  17. Sep 18, 2017 at 11:33 PM
    pngo121
    Phi
    Pittsburg, CA
    dont even see that as an option but if its something available then ok. was just trying to make buyers aware.
  18. Sep 18, 2017 at 11:33 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    True slider are welded. And you are absolutely correct about all "sliders" that bolt to the rocker panels
  19. Sep 18, 2017 at 11:36 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Yeah they don't sell it directly through the website. The guy I bought them off called in and ordered them. He hadn't done the mod but was selling the standoffs with the sliders.
    pngo121[QUOTED] likes this.
