Avid Light bar and Hi-lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeffvt0508, Nov 4, 2013.
  1. Nov 4, 2013 at 10:24 AM
    Jeffvt0508
    Jeffvt0508 [OP] Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have an Avid light bar.. and ONLY want to mount my hi-lift to it.. using the ARB hi-lift tube mounts.. so i know the hi-lift is 70 lbs.. can the light bar withstand that much weight?[​IMG]
  2. Nov 4, 2013 at 10:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't. I know the Avid bars are a little more stout than the average light bar but I wouldn't throw a hi-lift on it. I'd get the bed mounts instead.
  3. Nov 4, 2013 at 10:27 AM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    I wouldn't see why not. As long as there is room between the bar and the bumper for the mounts, it should work. And if the lift will fit without being too close to the bumper as well.
  4. Nov 4, 2013 at 10:29 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    i have bed mounts but i'm tryin to clean out my bed for sleeping/cooking and just not too great w/ a muddy hi-lift at your head or feet..
  5. Nov 4, 2013 at 10:36 AM
    Pugga
    Massachusetts
    If you do it, I'd mount it to the lower bar, not the upper. That light bar is just end mounted down low, so the closer you can get the hi lift mounts to where the bar attaches to the truck, the better. On the top bar, that's a lot of weight that will be shaking around at a good distance from the mount point.
  6. Nov 4, 2013 at 10:46 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I sat on my avid bar when I had it all the time. Im about 190lbs and the thng didnt move. I think hi-lifts are better in the bed though.
  7. Nov 4, 2013 at 5:19 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    yea I agree better in the bed.. but I am going to get a soft topper but don't want the roll cage (yet) to attach it and the maxtrax to it..just want my sleeping area clean and clear..
  8. Nov 5, 2013 at 3:27 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I have an Avid bar. Granted it is for lights, but as mentioned, it is pretty strong but does flex when you give it a good pull by hand.
    I would consider the blocking of the headlights a possibility before committing to that location.
    PK
  9. Nov 5, 2013 at 3:48 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    i agree i just didn't want to spend the money on them if it wasn't going to work.. I have sat on the bar and used it to climb onto my hood (when cleaning) so i assumed if i could stand on it.. it could handle 70 lbs of hi-lift.. I do like the bottom tube as the mounting possibility .... just wanted everyone's opinion before pulling trigger
