Avid Sliders ... weld on vs bolt on ... point of no return ...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PreRunner, Mar 21, 2010.
  1. Mar 21, 2010 at 8:09 AM
    PreRunner
    PreRunner [OP] Well-Known Member
    I ordered the bolt ons because the most i'll see is an occasional dirt road. I wanted mainly the looks, and some decent protection. I also like how I can install them myself because i live in central florida, where there are no professionals and everyone is retarded. I would get my truck back with them welded on upside-down or something.
    Did i make the right choice? I just placed the order so I could most likely change. No biggie if I can't. Bolt ons just seems more appropriate for me. Thoughts? :eek:
  2. Mar 21, 2010 at 8:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    I think you'd be surprised about finding someone competent to weld them on. Most offroad shops are small but plenty good at what they do.
    Bolt on will work fine
  3. Mar 21, 2010 at 8:39 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    pre-runner,
    Not sure where you are in Floriduh' ;) but one of TW's new sponsors is hiding in Ft.Myers ( looking at their work,I'd say there competent;):cool: ) and Central Florida has many " Mom & Pop" weld shops that DO KNOW their stuff....
    That being said,I will be "Bolting" on my Sliders also.....My NEW frame will not be welded so ALL "Mods" need to FIT exact or they will not be purchased...
    Just my 2 cents....enjoy your Sunday...
    S
  4. Mar 21, 2010 at 9:33 AM
    PreRunner
    so is welding bad for a new frame? (mine is new also).
    so far it seems i chose wisely, for me anyway
  5. Mar 21, 2010 at 10:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Some folks will say that welding to a new frame can cause warping and weak points in the frame. I counter that if welding was bad for the frame- They would have a hard time putting it together. If it's done correctly- You would be fine with welding.
  6. Mar 21, 2010 at 10:26 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Drilling 20 something holes in the frame for bolt on sure as hell doesn't strengthen it either.
  7. Mar 21, 2010 at 11:01 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    After talking to Demello and watching them weld my new sliders on I have no doubts that welded sliders are better.
    And I do see that you mention that your not actually going to use your bolt on Avids like sliders and thats a good thing because they are not actually made to support the weight of the truck either on the trails or for a Hi-lift jack. Avid's bolt on's are just Nerf bars.
  8. Mar 21, 2010 at 11:09 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Yeah there are some bolt ons that will Shrockworks and Beef's but most won't. But Avid tells you themselves they won't support the weight.
  9. Mar 21, 2010 at 11:53 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Exactly, from their site:
    "The 2005+ Tacoma Sliders can be ordered to bolt on or weld on. The bolt-on sliders attach to the factory running board mounts. The bolt-on sliders can be used as steps, dent protection, and light off-roading, but are not designed to support the weight of the truck. The weld on sliders are designed for the more extreme off-roading."
    Attached to the running board mounts.......nerf bars
  10. Mar 21, 2010 at 11:54 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    imo, all the advantages point to bolt on.
    #1. frame sees no heat, only 4 new holes on each lower rail, which is 2 frames in one anyway.
    #2. option to remove for painting, selling, or replacement if one or both were to get trashed somehow.
    #3. DIY install in your driveway.
    #4. very strong if mounting locations are well thought out and hardware is grade 8 or higher.
    I'm not against weld on's at all either, and wouldn't worry about the frame strength if welded on by a competent welder.
  11. Mar 21, 2010 at 12:07 PM
    PreRunner
    i thought i wouldn't have to be drilling any holes? was i wrong?
  12. Mar 21, 2010 at 12:10 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Some require additional holes to be drilled. Stock up on drill bits and cutting oil :)
  13. Mar 21, 2010 at 12:57 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I have Shrockworks bolted to the frame and these things are solid. I see nothing wrong with bolting them to the frame. I had to drill 6 holes in my frame and it wasn't that hard and its a job I did myself in the snow.
    I'm not sure how the Avid's are by attaching to the factory running board holes. Personaly I'd rather them be attached to the frame.
  14. Mar 21, 2010 at 1:00 PM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    Just make sure the mounting holes on your sliders match up correctly to the ones on your truck before you paint them. My passenger side mounting holes were way off and I was only able to install bolts to three of the six holes.
  15. Mar 21, 2010 at 1:09 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    My sliders use the factory holes in the side of the frame with nut plates on the inside, but there are 4 holes per side that need to be drilled on the lower rail, there's just really no other way...if they're to be strong. Toyota has a million holes in their frames, just nothing below to bolt to.
    I used a old drill bit set (that most of us have in the garage) a Black & Decker 1/2" drill plugged in, and started with a small pilot hole, and basically worked up every other bit until I got to 1/2". It was easy, and I recommend this method rather than starting with a large bit because it'll heat up and heat treat the metal in that area and make it even worse than it already is. Start small and work up especially since you're drilling through 2 layers of frame.
  16. Mar 21, 2010 at 1:31 PM
    rmerchant3
    rmerchant3 Insert nonsense here
    What about allpro's? Are they any good? I can't tell if they are bold on or weld on.
  17. Mar 22, 2010 at 7:25 AM
    PreRunner
    Just to clarify ... I spoke with brandon at avid offroad by email and he said they will just bolt on, and they send all the hardware. No drilling for me! I have a single cab. :D
  18. Mar 22, 2010 at 7:52 AM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    So I was looking into these possibly instead of my nfabs. I don't off road and just want them for step bars/looks. Now when they say bolt on do they bolt onto the frame with drilled holes? Or do they also sell them that just bolt into the factory step bar locals?
  19. Mar 22, 2010 at 8:04 AM
    PreRunner
    they are supposed to bolt to the factory steprail location on the cab
