Avid step rail coating???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecr6cyl10, Nov 27, 2011.
Coating Ideas
Poll closed Dec 27, 2011.
  1. Spray Paint
    0 vote(s)
    0.0%
  2. DIY spray on bedliner in a can
    1 vote(s)
    20.0%
  3. Powder coating
    2 vote(s)
    40.0%
  4. Line X
    2 vote(s)
    40.0%
  1. Nov 27, 2011 at 4:35 PM
    ecr6cyl10
    ecr6cyl10 [OP] Well-Known Member
    Eddy
    Gilbert, AZ
    10 Prerunner Dble Cab Offorad
    Defiant Light bar with 12" LED light bar and 2 Rigid dually floods. 3" Icon lift in the front with TC UCA's and 1.5" add a leaf in the rear [url=http://www.tacomaworld.com/gallery/showphoto.php/photo/198098/cat/500][img]http://www.tacomaworld.com/gallery/data/500/medium/My_Truck54.jpg[/img][/url]
    I was wondering what everyone suggestions are for coating my new side rails I ordered.
  2. Nov 27, 2011 at 4:41 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    Should get my Avids in the next week or so too. I am flipping back and forth between a satin black rattle can job or having them powder coated. Rattle cans will cost about $25 and powder coating is $175 in my area. Doing it myself is cheaper and can be touched up easily but powder coating will look better and last longer. What to do...
  3. Nov 27, 2011 at 4:43 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    i line x'ed my light bar, and no problems, its super thick, and if anything flies up and hits it you dont have to worry. I think its worth the money to protect the steel, plus since there not sliders but step rails its not likely they will get damged on rocks or anything that could ruin the line x.
  4. Nov 27, 2011 at 4:45 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    When I get my Avid light bar and side steps I'm getting both done with Line-x.
  5. Nov 27, 2011 at 6:35 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    I am really thinking about line X I am just wondering how much it will cost?
  6. Nov 27, 2011 at 6:41 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    are they the bolt on step sliders, or actual sliders? if you plan on actually using them for their intended purpose I'd rattlecan them, easy touch up and you won't dishing out over a hundred dollars on something made to get beat up.
  7. Nov 27, 2011 at 6:43 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    They are bolt on steps rails.
  8. Nov 27, 2011 at 6:43 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I had powdercoating done on my front bar and it was the coating on my nerf bars. Two years in chicago salt winters and they were rotting away from rust. Got weld on sliders and had them line-x'd. Was so impressed with the line-x material I had my front bar done in it too. I dont want to waste my time every summer sanding and re-coating. In weather conditions like we have line-x is the cheaper and easier way to go in the long run
  9. Nov 27, 2011 at 6:44 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    They look kinda like yours tacomalex, how did you do yours?
  10. Nov 27, 2011 at 8:46 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    Anyone used spray on bed line on there?
  11. Nov 29, 2011 at 9:54 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    Talked with Brandon at Avid and I am going to have them powder coated with an impact resistant coating.
    Thanks for everyones input.
  12. Dec 11, 2011 at 6:02 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    Only a few days and I should have my new side rails. Thanks for everyone help.
