AVS BUG Deflector II on Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBella, Jan 12, 2016.
  1. Sep 29, 2017 at 7:00 AM
    #121
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    What is the difference between the Bug Deflector and the Bug Deflector II?? I got the regular Bug Deflector, but I can see no difference between either!
  2. Nov 14, 2017 at 2:00 PM
    #122
    Split|Circuit
    Split|Circuit Well-Known Member
    Valley of the Sun
    2017 TRD Off 4x4 DblCab, White, Blk/Org Int
    Bone Stock
    I believe the Deflector II is higher profile. How was the install and fitment? Do you have confidence that it won't rub?
    Also, on a sidenote, what would be the correct name for the little, white retaining clips that AVS (and other brands) use to mount the deflectors? I am in need of some new ones. They are the white, nylon square pieces that allow a screw to thread-in and spread the spades apart, ensuring a tight fit. Anyone know if Autozone, O'Reillys sells them?
  3. Apr 22, 2018 at 10:37 PM
    #123
    Kingsunseri
    Kingsunseri Well-Known Member
    BRIAN
    2016 Red TRD Sport Tacoma RWD
    Which one is this
  4. Apr 22, 2018 at 11:20 PM
    #124
    DSSK
    DSSK Well-Known Member
    2017 White Tacoma Limited 2WD
    Love the look of that hood!
  5. Apr 23, 2018 at 6:03 AM
    #125
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
  6. Apr 23, 2018 at 6:22 AM
    #126
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Bugflector II
  7. Apr 23, 2018 at 8:45 AM
    #127
    DESportTRD
    Yes.... had been on since Memorial Day weekend 2017. No issues, doesn’t rub, I wash and wax etc under it also. If you install as per the instructions you will not have any issues.
  8. Jun 27, 2018 at 11:25 AM
    #128
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Anyone have the EGR bug shield. Looks the best but want to know how installs and if it Has any of the same problems that some of these other bug deflectors have
    Personally, I can think of some solutions For the issues presented here.
    1) would be to have a design that replaces the stock weather stripping with thinner seals to allow more clearance for the deflector and prevent it from bending up towards the metal.
    2) have a design that uses thin metal brackets or longer mounting area that pushes the deflector up and away from the hood to prevent any contact with painted edge or top of the hood
    3) have the deflector include a soft non abrasive insulator like thin foam that is attached to the inside edge of the deflector. This way there is a cushion between the deflector and your paint without adhering anything to the hood itself.
    4) any combination of the above ideas
  9. Jul 27, 2018 at 7:42 AM
    #129
    brotherparker
    brotherparker Well-Known Member
    Nova Scotia, Canada
    2016 Access Cab TRD O/R 6MT
    I just installed one of these yesterday. Seems very tight where it curves around from under the hood. I am worried about it chafing the leading edge of the hood. Anyone had trouble with that so far?
  10. Jul 27, 2018 at 10:26 AM
    #130
    DESportTRD
    AVS Bugflector II has no rub issues on my hood after 1 year.
    Love it...:amen:
  11. May 7, 2019 at 2:19 PM
    #131
    silverflash
    silverflash Well-Known Member
    Bill
    Harnett county NC
    2019 TRD 4x4 OFFROAD DCSB Auto Quicksand
    tyger armor side bars tyger tri-fold tonneau cover avs bug deflector II scangauge II
    i installed one of these today and the drivers side near the edge of the grille has a nice little mark in it now. I re-adjusted but i think it doesn't make a difference. it looks good and should keep the bug of the glass. plastic doesn't rust so i don't really care abt a tiny nick. I am going to send it.
  12. May 7, 2019 at 2:58 PM
    #132
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    I never thought I would like these but when my Tacoma arrived it already had one on it and I really liked the way it looks, especially with my Pro grille and ARB bumper. Good thing is when the dealership installed the item they never updated their system so it was free. Same goes for the tube steps. :rofl:
    silverflash likes this.
  13. Mar 30, 2024 at 8:17 AM
    #133
    MrBigFeathers
    MrBigFeathers Active Member
    2022 DCSB TRD OR (MBM)
    I know this thread is very old, but I just put the AVS Bugflector II on my 22 and ended up taking it off and returning it. No matter how I adjusted it it was making contact with my passenger side headlight housing and the grille surround. I don't know if it was warped or my hood is a little uneven but I now have a couple chips in my headlight housing and grille surround.
    Although I love the bug deflectors and have had them on all my previous Toyotas, I had to give up on this one. Wasn't worth any further damage to me.
    I'd say if you have one and are wondering if it is making contact, see if you can slide a piece of paper under it with the hood closed. I could on the driver side but never was able to on the passenger side. That's how I knew it was just resting on my headlight even with the hood bump stops as far out as they could go.
