AVS or Weathertech in channel window vents?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scott17818, Apr 24, 2020.
  1. Apr 24, 2020 at 9:30 AM
    #41
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    I have the standard AVS in channel and they work great! I too had to send my first set back ha
    You can still get your soap mitt underneath them when you wash your truck. I think with the low profiles you wouldnt be able to. Not that is a huge deal or anything. I wash my truck just a handful of times of year, but always seem to notice this when i do.
  2. Apr 24, 2020 at 9:36 AM
    #42
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Thanks guys, decisions decisions,,,
  3. Apr 24, 2020 at 9:36 AM
    #43
    cop414
    Tim
    Central PA
    Good to know.
  4. Apr 24, 2020 at 9:44 AM
    #44
    dleriche
    dleriche Wanee Warrior
    D.J.
    Leander, TX
    2019 White ORD DCSB AT
    I have used both WeatherTech and AVS in-channel versions in the past. Both are solid options. I've settled on AVS mostly because they are less expensive when I am shopping for them. And if any of you are still smokers out there, do not get the slim version. Stick to the standard.
  5. Apr 24, 2020 at 9:45 AM
    #45
    dleriche
    D.J.
    Leander, TX
    Yeah, and this too
  6. Apr 24, 2020 at 12:10 PM
    #46
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I’ve had avs in channel for months now and no problem. Just know that once you get the in channel rain guards on and keep it on with the window up for a long period of time, the window run channel molding might deform a little, or I’ve been told.
  7. Apr 24, 2020 at 12:20 PM
    #47
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    AVS standard in-channel, no blind spot by the mirror vs WT.
  8. Apr 24, 2020 at 12:33 PM
    #48
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    You're going to have to explain that one to me.
  9. Apr 24, 2020 at 12:34 PM
    #49
    cop414
    Tim
    Central PA
    I believe that the weather techs go farther down the length of the window frame possibly blocking part of the mirror view? That’s my take on it anyway.
    On second thought I’m stumped too, the wt can’t go any further down on the frame than the others, not sure? I’m stumped, but that doesn’t take much!
  10. Apr 24, 2020 at 12:44 PM
    #50
    JG358
    JG358 Well-Known Member
    Jake
    Colorado
    16 Tacoma TRD OR DCSB
    The WTs I looked at went down to the mirror and then turned down and continued to the bottom window seal but I dont think it would matter much.
  11. Apr 24, 2020 at 12:45 PM
    #51
    Devious6
    Mark
    Right - they do come all the way to the bottom of the channel. But, first...you can see through them but they don't extend anywhere near into view of your mirror. Second, the mirror itself creates a "blind spot" since you can't see through that. I actually had to go sit in my truck to try to figure this out. I must be missing something.
  12. Apr 24, 2020 at 12:55 PM
    #52
    Devious6
    Mark
    Just took this in my garage.
  13. Apr 24, 2020 at 1:53 PM
    #53
    dleriche
    D.J.
    Leander, TX
    OP. Just for comparison sake, this is the same type photo with AVS installed. Basically the only real difference between the two. You can't go wrong with either choice. Just make sure to keep pressure towards the outside of the vehicle on the vents when rolling up the window right after install. This will ensure you won't crack them and allow window to roll up fully. I cracked a set once not doing this, that's how I know.
    Devious6[QUOTED] likes this.
  14. Apr 24, 2020 at 1:54 PM
    #54
    cop414
    Tim
    Central PA
    Ok, these are the wt’s then?
  15. Apr 24, 2020 at 1:55 PM
    #55
    cop414
    Tim
    Central PA
    Perfect, those two pics answer a lot of questions, thanks guys.
    Devious6 likes this.
  16. Apr 24, 2020 at 1:55 PM
    #56
    dleriche
    D.J.
    Leander, TX
    Yes
  17. Apr 24, 2020 at 2:00 PM
    #57
    cop414
    Tim
    Central PA
    The fact that the AVS leave that small bottom front trim uncovered is there any problem when the window is cracked with rain coming in at that point? I like the AVS look better but the WT seems like better coverage.
    I assume that with the window only down an inch or two that uncovered portion would still be sealed against the trim, at least that’s what it looks like in mine.
  18. Apr 24, 2020 at 2:50 PM
    #58
    Devious6
    Mark
    Yes, these are the WTs.
  19. Apr 24, 2020 at 2:57 PM
    #59
    waltuo
    waltuo Well-Known Member
    Toyotas
    I’ve had weathertechs on my 2nd gen. No issues but decided to go with avs on my 3rd gen. Should be here tomorrow. The price point on the ava is definitely a plus. Trying out the low pro dark smoke
  20. Apr 24, 2020 at 3:11 PM
    #60
    dleriche
    D.J.
    Leander, TX
    No issues with the rain with the window cracked 1"-2"
