Aw9d's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Aw9d, May 16, 2012.
  1. Oct 7, 2014 at 2:33 PM
    #201
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup:
  2. Oct 7, 2014 at 7:06 PM
    #202
    Aw9d
    Aw9d [OP] That one guy
    Lights gitter a bit. I think it's the cap for the ds2 bulbs.
  3. Oct 7, 2014 at 7:16 PM
    #203
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    epoxy them bishes..
  4. Oct 7, 2014 at 7:31 PM
    #204
    Aw9d
    Lol. I'll figure it out. Noy happy with the ds2 "plug n play" my ass projectors
  5. Oct 7, 2014 at 7:33 PM
    #205
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Nice! Halos look really good!
  6. Oct 8, 2014 at 10:16 AM
    #206
    Aw9d
    ^Thanks man! Now that I know how these DS2's fit this would be a pretty easy job.
  7. Oct 8, 2014 at 12:10 PM
    #207
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Same, my retro took about 4 days... Now i could probably complete one in 2.
  8. Oct 8, 2014 at 12:15 PM
    #208
    Aw9d
    This is my second one I've done for myself. My first one took less than a few hours if you don't include time for painting. This one was around 20+ because nothing fits right.
  9. Oct 8, 2014 at 12:23 PM
    #209
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Oh wow, yeah i did see some of your posts about having to cut some things... Why did you change? Better light output?
  10. Oct 8, 2014 at 12:36 PM
    #210
    Aw9d
    I had the mini DS2 1.0's and the chrome inside one projector fell out, hit the bulb and burned everything up. No real damage other than the bulb was trashed. So I bought all new ones.
    The new 3.0's DS2's require cutting. It's not hard, but I must of spent 10 hours trying to find away to make them fit without cutting since TRS kept telling me they require not modification to the housing. Which is untrue.
    I do have to say the light output is really damn good on these projectors!
  11. Oct 8, 2014 at 12:44 PM
    #211
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I also got the D2S 3.0... I have nothing to compare it to but the light output is MUCH better then stock haha :D
  12. Oct 8, 2014 at 12:45 PM
    #212
    Aw9d
    Between version 1 and 3 the difference is 'day and night'.
    Did you have to cut/trim to get your DS2 3.0's installed?
  13. Oct 8, 2014 at 12:56 PM
    #213
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I did, but is wasn't serious. For me to get the lock nut to turn i had to dremel out some of the plastic on the back of the headlight. TRS sent me the hexagon lock nut. I saw on the website the have a circular lock nut which would have worked better in my case because i dont think i would have had to cut anything. But its alright, pretty happy overall.
  14. Oct 8, 2014 at 1:00 PM
    #214
    Aw9d
    I got both lock nuts, the hex I had to cut the plastics down. The round one was too thick and wouldn't allow the DS2 bulb cap to get enough threads to hold in place.
  15. Oct 8, 2014 at 1:14 PM
    #215
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Ah, i see. I thought either lock nut would come with problems... Like i said, i only had minimal trimming so i wasn't to upset. But i see on your pics, looks like you had to do quite a bit of trimming.
  16. Oct 10, 2014 at 12:32 AM
    #216
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    he-he
  17. Oct 10, 2014 at 10:28 AM
    #217
    Aw9d
    Some good looking trucks right there.
  18. Oct 10, 2014 at 10:37 AM
    #218
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    x2 Also did you know that Betty White is older than sliced bread, as sliced bread started being sold in the year 1928. Betty white was born in 1922.
  19. Oct 10, 2014 at 10:44 AM
    #219
    Aw9d
    I didn’t know that. Did you know she was hot when she was young?
  20. Oct 10, 2014 at 11:01 AM
    #220
    JTS2016TACO
    Jamie
    Chandler, AZ
    I did not know that haha
