AWD warning light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jd4, Sep 22, 2024.
  1. Sep 22, 2024 at 8:56 AM
    jd4
    jd4 [OP] New Member
    The red light is flashing on the dash. Where does one start with this issue?
  2. Sep 22, 2024 at 9:05 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check that your RR DIFF LOCK button isn't depressed.
    jd4[OP], Superdave1.0 and TnShooter like this.
  3. Sep 22, 2024 at 9:26 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you have a Diff Lock. The button will be on the left side of the steering wheel.
    Dm93, jd4[OP] and Superdave1.0 like this.
  4. Sep 22, 2024 at 9:51 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    We don’t have AWD, just 4WD. :)
    jackn7 and Dm93 like this.
  5. Sep 22, 2024 at 9:57 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What position is the 4WD switch?
  6. Sep 22, 2024 at 10:21 AM
    TnShooter
    Deogee
    STOCK
    4WD Hi light is green.
    Lo is Yellow.
    The only Red light associated with the 4WD system would be the Rear Diff Lock light.
    Which is why Dm93 suggested checking the Locker switch.
    Dm93 likes this.
  7. Sep 22, 2024 at 10:22 AM
    jd4
    jd4 [OP] New Member
    Thank you to all who responded especially TnShooter and Dm93! Problem resolved.
    Knudsen, jackn7, Dm93 and 1 other person like this.
  8. Sep 22, 2024 at 10:57 AM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Always good to report back on a positive outcome.
    TnShooter likes this.
