Awesome Tailgate Anti-theft device
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackZEBRA, Jan 15, 2023.
  1. Jan 18, 2023 at 8:15 AM
    #61
    Chucky888_2021_TRD_OR
    Chucky888_2021_TRD_OR Live free and drive Taco
    Ching
    Osseo, MN
    2021 TRD OR DCSB
    I am too lazy or forgetful to take the key out to lock/unlock the tail gate every time.
    The hose clamp is just too ugly and "cheap" looking, SaBellco is too expensive for me.
    This "hook" was just right for me and I even spent a few bucks more to powder coat it, and installed OEM power lock.
    I do remember the factory screw was a bit of pain to remove, you have to use the right Torx size, the wrong size can strip it out easily.
    blackZEBRA[OP] likes this.
  2. Jan 18, 2023 at 8:18 AM
    #62
    blackZEBRA
    blackZEBRA [OP] Well-Known Member
    California
    '23 TRD OR DCLB
    Yes, it makes no sense to use the wrong size torx bit to remove the bolt. You need to use a T40. I double checked with @christian06 before I attempted to remove the factory bolt!
  3. Jan 18, 2023 at 8:26 AM
    #63
    Ching
    Osseo, MN
    2021 TRD OR DCSB
    The factory torx screw, as I remembered has a smaller head than the security Trox bit (T40) brought that from Christian.
    e.g. If you used a T27 on T30 screw it will fit in but strip the head off.
  4. Jan 18, 2023 at 8:28 AM
    #64
    blackZEBRA
    California
    '23 TRD OR DCLB
    The screw you buy from Christian is a T45, the factory bolt is a T40.
  5. Jan 18, 2023 at 8:39 AM
    #65
    Ching
    Osseo, MN
    2021 TRD OR DCSB
    Yes, that is right.
    I was trying to use a T35 bit or somthing smaller to remove factory screw and almost trip the head. Use the right bit!
  6. Jan 18, 2023 at 8:41 AM
    #66
    blackZEBRA
    California
    '23 TRD OR DCLB
    That'll do it. hah
  7. Jan 18, 2023 at 8:47 AM
    #67
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    I was going to suggest an impact wrench... there's a tool for every job!
    MonkeyChief likes this.
  8. Jan 18, 2023 at 8:59 AM
    #68
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    The factory screw is a T40
    The safety screw is a T45
    An impact driver does the job quite well, not a drill driver. The one you hit with a hammer works perfect, and you definitely will strip it out if you use the wrong size bit.
  9. Jan 20, 2023 at 5:25 PM
    #69
    jonnybrowning
    jonnybrowning Somewhat Sarcastic
    Jon
    2023 Taco TRD Offroad MGM
    Kroil……..check
    Soldering iron to heat the bolt……check
    Impact driver from Harbor Freight……..check
    T44 impact bits…….check
    T45 security bit………check
    Ratchets………check
    Hammer………check
    Patience……I’ll try to find some
    OK, I’m placing my order…..
    Josephray70 likes this.
  10. Jan 20, 2023 at 9:21 PM
    #70
    mabupa
    mabupa Well-Known Member
    Miguel
    2021 trd off-road 6 speed manual
    Forgot the screw extractor in case all else fails. Lol
  11. Jan 21, 2023 at 4:58 AM
    #71
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Pro tip: when you get ready to remove that screw from the tailgate, take the tailgate off of your truck and stand it on it's end in the grass, with cardboard and a towel to protect it. This was easier for me to get some well placed whacks on the impact screwdriver focused directly into that screw.
  12. Jan 21, 2023 at 5:48 AM
    #72
    jonnybrowning
    Jon
    Yes I will remove the tailgate, and take off the inner panel so I can apply heat to the end of the bolt. Thanks.
  13. Jan 21, 2023 at 6:36 AM
    #73
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Please forgive my ignorance but I had no idea that having a tailgate stolen was that prevalent. Don’t anyone that has been a victim of this type of theft. But thieves are everywhere, I suppose. I guess we all have the risk of waking up and be missing a catalytic converter too. We live in a broken world. I have a factory locking tailgate, should I still get one of the products being discussed here ?
  14. Jan 21, 2023 at 6:52 AM
    #74
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    @bmg88201
    I installed the OEM TailGate Lock first and then installed the SaBellCo (after trying unsuccessfully with the clamp).
    Peace of mind is my goal. If for some reason, an attempt is made to take something off my truck, this will be a deterrent.
  15. Jan 21, 2023 at 6:55 AM
    #75
    christian06
    Cali
    Looks like you got it covered, thx
  16. Jan 21, 2023 at 2:40 PM
    #76
    tacoma warrior
    tacoma warrior Well-Known Member
    2020 Tacoma SR5 silver
    Question, I was trying to remove the factory t40, but I stripped the head, tomorrow I'm going to a shop to weld a nut and remove that fricking screw. My question is when the anti-theft device is in place, how I'm going to torke the t45 screw? Because there's no space for the tool.
  17. Jan 21, 2023 at 3:12 PM
    #77
    Metric Rider
    Metric Rider Well-Known Member
    Gar
    Valley Farms, AZ
    2017 Tacoma TRD Sport
    Body Armor Front Bumper, Smittybilt XRC 9.5 GEN2 Winch, Fab Fours rear bumper, 400 watt inverter anytime, Front camera, On-board ARB air compressor.
    @christian06
    Thanks for providing these Chris, just order one for my 3rd gen.
    Way Way Afar likes this.
  18. Jan 21, 2023 at 7:56 PM
    #78
    christian06
    Cali
    Awsome, thx for your support.
  19. Jan 21, 2023 at 7:59 PM
    #79
    christian06
    Cali
    Take the ta
    Take the tailgate off, you'll have better leverage
  20. Jan 21, 2023 at 8:03 PM
    #80
    Metric Rider
    Gar
    Valley Farms, AZ
    You can also just lift the tailgate a few inches after you install it. Should provide more then enough room to get a torque wrench on it.
