axel seal replacment
Discussion in 'Suspension' started by mike sacc, Apr 3, 2011.
  1. Apr 3, 2011 at 11:58 AM
    mike sacc
    mike sacc [OP] Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    does any body have info on changing drivers side front axel seal.i tried to search for previouse posts but had no luck . any info would be helpfull, thanks.
  2. Apr 4, 2011 at 8:24 PM
    cb04
    cb04 Member
    north texas
    04 ext cab sr5 trd 4 x 4
    I got a new one from the toy dealership. Quite an ordeal. Must remove wheel, brake, rotor, coilover, driveshaft. pry out old seal. Install new seal slightly inside of housing. try to install the same depth all around. Can get info from fsm. search fsm on this site.
  3. Apr 4, 2011 at 8:26 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Diff side or hub side?
  4. Apr 4, 2011 at 8:32 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I have had a few beers and whan I saw axel seal I thought something totally different. I may be in the wrong place....that's what she said...
  5. Apr 4, 2011 at 8:34 PM
    S.B.
    Sean
    yes, you be drunk.
  6. Apr 4, 2011 at 8:41 PM
    Monkeysuncle
    Kevin
    Florida
    All Kidding aside, I think I read a post on what caused the seal to malfunction in the first place and that is where the "Pandoras Box" of problems opened up, let me take a look and see if I can find that post.
  7. Apr 4, 2011 at 8:43 PM
    S.B.
    Sean
    If its the inner one (one the diff), I just had mine replaced today under the power train warranty.
  8. Apr 4, 2011 at 8:44 PM
    S.B.
    Sean
    I would like to see the thread/ post also.
  9. Apr 4, 2011 at 8:44 PM
    Monkeysuncle
    Kevin
    Florida
    What year,transmission,motor,color and social security number...wait, just the year,trans motor will work. Just to be sure because you list two Tacomas in your Sig...AND my good friend is a Toyota Mechanic, so if all it takes me to "Phone a Friend" and give you an answer then I will be happy to do so.
  10. Apr 4, 2011 at 8:48 PM
    S.B.
    Sean
    Me? 08, v-6, auto
  11. Apr 4, 2011 at 9:02 PM
    Monkeysuncle
    Kevin
    Florida
    The Op has 2 in his profile, so it would be much easier for me to simply call my friend who works on cars and is the master mechanic at a local import garage and ask him a question, but I know it is a pain in the butt. He told me a story about seals, berrings and having to replace them in a newer Toyota with ABS and the computer wording hew threw out at me, it made my head hurt. They have made the most simple things so difficult these days
  12. Apr 4, 2011 at 9:04 PM
    S.B.
    Sean
    yes, this computer crap is confusing.
  13. Apr 5, 2011 at 3:58 PM
    mike sacc
    r.i.
    sorry its the 2001 ,2.7,5 speed manual.
  14. Apr 9, 2011 at 6:33 PM
    mike sacc
    r.i.
    changed the seal today , drove it about 30 miles so far no leaks. took some short cuts. disconnected the lower ball joint, tie rod and the axel nut . bungeed everything out of the way and it went pretty good.;)
