AxelWrap help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, May 1, 2009.
  1. May 1, 2009 at 10:38 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    How do you fix this? AAL?
  2. May 1, 2009 at 10:51 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Traction bar. URD use to make one for the prerunners, but not anymore. I have a few friends with the urd one on their xr's, and it makes a huge difference. If it wasn't so damn expensive I'd have one lol.
  3. May 1, 2009 at 10:56 PM
    Lentsnh
    It just happens if I brake pretty hard and then accelerate right after
  4. May 1, 2009 at 11:06 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I've got the leaf TSB and an AAL and that helped mine out alot.
  5. May 1, 2009 at 11:13 PM
    Lentsnh
    Didnt you get the TSB leaf from a Tundra? I think I remember seeing that on your build thread.
  6. May 2, 2009 at 12:10 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    the 10 leaf Deaver pack took all the axle wrap away, I got them cuz I couldn't do the TSB
  7. May 2, 2009 at 1:18 AM
    RelentlessFab
    Eric
    Sparks, NV
    Well, it is one for a tundra, but that was only because it was the best fitting option that Wheelers had in stock to give me. I had to cut a tad off one end for it to fit. Anyways, i'm reasonably sure that its pretty much the same leaf, it would just lift the back of the Tacoma say 2" where it would lift the tundra 1.5".:cool:
  8. May 2, 2009 at 1:22 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I have the Toytec AAL. Still have axle wrap. Pro Comp makes a trac bar. Go to 4wheelparts.com They have the bars and then you have to get the brackets too. Im going to get the OME Dakar leafs to fix my wrap, if that doesn't work, getting those trac bars and a Tom Woods dive shaft for a diff prob. Best of luck!
  9. May 2, 2009 at 2:55 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    try a set of the toytec axle shims.....easy install and should get rid of the takeoff vibe
  10. May 2, 2009 at 5:03 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Don't brake pretty hard and accelerate right after. It's not good for your gas mileage and if it induces axle wrap but isn't necessary (and I'm going to say there is a pretty limited number of cases where you should do that) just not doing it fixes the problem.
    An AAL is a good place to start traction bars is a bit extreme imo for a more or less stock ride to fix occasional wrap...
  11. May 2, 2009 at 5:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    A good AAL or stiffer leaf pak will help. Other than that..... it's just normal.
  12. May 2, 2009 at 6:03 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    X3
    (you knew I had to)
  13. May 2, 2009 at 6:13 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
  14. May 2, 2009 at 8:24 AM
    agtex42
    agtex42 Well-Known Member
    Agreed, the only cases I've seen where traction bars (ladder bars) are truly necessary are on spring-over type lifts with weaker spring packs designed for maximum flexibility. Less skinny pedal tends to be the best solution and it doesn't cost you a thing :thumbsup:
  15. May 2, 2009 at 11:56 AM
    Lentsnh
    I dont do it all the time. Some moron pulled out infront of me and then I was trying to get up to speed again.
    I will do the AAL. I wasn't planning on spending alot of money on this problem.
    I mean I dont mind it... Its only happened a few times. If I would get an AAL it would stop the axel wrap and lift my truck :thumbsup:
    2 birds with one stone
  16. May 2, 2009 at 1:10 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    An AAL will do that...but you'll still get axle wrap if you load the drive line up like that. No reason to hard accel out of the hole if you need to stop short...unless someone is about to hit you from behind- and then fuck axle wrap...I'll be JAMMIN on the skinny pedal.
  17. May 2, 2009 at 1:11 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    He lent (or anyone for that matter) How do you know you have axel wrap when you are the one driving?
  18. May 2, 2009 at 1:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You can feel it.... he rear wheels can "hop" as the springs load and unload. You can hear a clunking sound sometimes too...
  19. May 2, 2009 at 1:23 PM
    DanGer
    Ok cool, I was just wondering because sometime if I have to break hard with the manual tranny I will push in the clutch then reassess which gear i need. If I ever do it too quickly I lurch the truck by accident, so i was just wondering!
  20. May 2, 2009 at 1:25 PM
    dbbd1
    dbbd1 Well-Known Member
