Axle binding / Driveline windup... should I be worried?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by redaccount36, Mar 21, 2017.
  1. Mar 21, 2017 at 3:35 AM
    redaccount36
    redaccount36 [OP] Well-Known Member
    2017 DCSB Silver Limited
    I'm new to Tacomas and 4WD. Last night I just learned about part-time 4WD and how you are not supposed to drive it on pavement. Well last weekend just to test it out I had thrown it into 4LO and went up a winding road a bit. Is that little (less than a mile) distance enough to cause serious windup? Is the only reversal procedure to jack up one wheel? I didn't notice anything different in the truck and drove it home back in 2wd for like an hour. What, if anything, should I do?
  2. Mar 21, 2017 at 3:49 AM
    CJREX
    CJREX Well-Known Member
    Georgia
    You're fine.
    Your driveline is not wound up.
  3. Mar 21, 2017 at 3:50 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    4wd on a paved winding road? That is probably the worst way to test out your 4wd. Probably did put everything in a bind at some point.
    Might have caused unnecessary stress and wear. Doesn't sound like you broke anything. Just don't do it again.
    You should probably read the manual.
    Lakeboy and dYL0n like this.
  4. Mar 21, 2017 at 3:51 AM
    redaccount36
    Do you think it's still bound up? Should I try to jack it up on one wheel as I read somewhere to "reverse" it?
  5. Mar 21, 2017 at 4:23 AM
    Large
    Large Red
    I'm so confused with this statement. Just read the manual and drive the truck :confused:
    nDub, RIDERED67, MQQSE and 1 other person like this.
  6. Mar 21, 2017 at 4:25 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    You're truck is OK if you're not hearing any new strange noises; but don't do that on pavement, again. Ice or snow covered roads yes, but not dry or even wet roads.
    Read the attached links in @OffroadToy 's signature. They explain it very well. I found them very informative when I first joined the forum; my Tacoma was my first part-time 4WD vehicle too. ;)
    boynoyce likes this.
  7. Mar 21, 2017 at 4:26 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Who is Manual?
  8. Mar 21, 2017 at 4:46 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Why the hell would you do this?
  9. Mar 21, 2017 at 4:51 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    This is great...
    OP, no your driveline won't wind up like a spring. If you broke something changes are you would know it.
    Now stop driving on pavement in 4wd.
    And ill say it again.....this is why I don't buy used cars
    Lakeboy and boynoyce like this.
  10. Mar 21, 2017 at 4:53 AM
    redaccount36
    I was uneducated about it.
    As soon as I became aware of the problem, I did RTFM, but so far I have found little information about once you've done it how much stress and tension gets built up how quickly, and once it's built up does switching back into 2WD relieve it, is there a critical action that should be taken, etc. Everything seems to be vague on that point and even here it seems there's a wide range of opinion. If the question was confusing or upsetting, I imagine that's because I myself am confused, and I'm sorry if I upset you.
  11. Mar 21, 2017 at 4:54 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    Back ordered
    He's the guy who actually built the truck.
    Hecho en México
  12. Mar 21, 2017 at 4:55 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Well played ... very well played indeed. :)
    swordfish[QUOTED] likes this.
  13. Mar 21, 2017 at 4:56 AM
    RIDERED67
    Try to estimate the total number of tire rotations that occurred while you were in 4wd. Jack up the truck making sure all 4 wheels are in the air and with the transmission in drive and 4wd low engaged and the truck off simply counter rotate an equal number of rotations as your estimate.
    Easy peasy
    Nfarrall likes this.
  14. Mar 21, 2017 at 5:02 AM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    Don't worry, you probably didn't damage anything. No need for any odd jacking procedures. Just try not to use 4x4 on dry pavement anymore.
    MQQSE likes this.
  15. Mar 21, 2017 at 5:04 AM
    redaccount36
    Thank you greatly. Luckily my ignorance didn't cost me anything this time!
  16. Mar 21, 2017 at 5:06 AM
    ajm
    Anthony
    AZ
    1996 4x4
    Come on, no need for this. It was an honest question. Not everybody comes out of the womb understanding how a 4wd vehicle works.
    goose443, rlx02, PHLinPHX and 2 others like this.
  17. Mar 21, 2017 at 6:47 AM
    Woodrow F Call
    Colorful Colorado
    No. It will find a way to become unbound.... when you put it back in 2wd that will unbind anything.
  18. Mar 21, 2017 at 8:23 AM
    Nfarrall
    Nfarrall Well-Known Member
    Chester county, PA
    2017 QS DCSB SR5
    Drive it in reverse.
  19. Mar 21, 2017 at 9:20 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    No, the wind up occurs in 4WD only. Sometimes there can be so much binding that you cant get it out of 4WD. If this occurs, you can typically back straight up slowly to try and get it out, might have to make slow gradual turns in reverse. Driveline wind up will cause the driveline to make a thud and even make the truck lurch a bit when getting it back out of 4WD. That thud is the drivline becoming unbound suddenly.
    Even on gravel, turning tight in 4WD is going to cause driveline bind. Try to minimize it, and don't do it at all on dry pavement. This is why a Subaru AWD or similar system is superior on a road going car or SUV.
  20. Mar 21, 2017 at 12:59 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    There must be some crybaby in this thread that had my comment removed about jacking it up and putting it in reverse, but to be careful as doing it too long will cause the odometer to go backwards, reducing the miles shown? :luvya:
