Axle code
Discussion in 'Technical Chat' started by Model 70, Oct 27, 2011.
  1. Oct 27, 2011 at 8:25 PM
    Model 70
    Model 70 [OP] Well-Known Member
    Central Oklahoma
    97 Tacoma 4X4 Pristine Clean
    JRS leaves, Monroe Redi Struts., Later Taco Mini Header, Alpine Tunes.
    Does the axle code for the rear axle also apply to the front axle on a bone stock 1997 4X4? I am looking at locker options for the front differential.
  2. Oct 27, 2011 at 8:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Huh? I *think* you're asking if you have the same differential assembly front and rear. If so, the answer is no. Same gear ratio front and rear, but different differential.
  3. Oct 28, 2011 at 4:12 AM
    Model 70
    Central Oklahoma
    I actually need to find the ring gear size and spline count on the axles. Some of the lockers I am considering are the Aussie, and the Tru Track
  4. Oct 28, 2011 at 4:27 AM
    ToyotaPartsMan
    ToyotaPartsMan Member
    NC
    '14 TRD Sport V6 4x4
    PM me your VIN I can see what your ring gear size is usually by VIN. Work in a Toyota Parts Dept.
