Axle Houseing Swap Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SlimBo84, Oct 22, 2019.
  1. Oct 22, 2019 at 4:45 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yes
  2. Oct 22, 2019 at 4:45 PM
    SlimBo84
    SlimBo84 [OP] Some Guy
    Colorado
    '11 TRD Off-Road
    ATO front bumper, Body Armor rear bumper w/ swing arm, AP sliders and front skid, ATO bed crossbars w/ Thule M.O.A.B. basket, Warn VR8000-s, 285/70R/17 Goodyear Wrangler MT/R w/ Kevlar, 17" XD Series wheels, Fox 2.5 coilovers w/ res., Fox 2.5 shocks w/ res., AP Expo leaf springs, extended rear breaklines, VIAIR HD OBA, 2x 9.5" HID LightForce, Rigid fog lights, and much more to come.
    Please explain. From what I know now: all bolts for assembly will line up, gears are 3.73 in both. I know I wouldn't have the elocker. One thing I am not clear on is the difference with the 8.4 and 8" rings
    TireFire likes this.
  3. Oct 22, 2019 at 4:46 PM
    SlimBo84
    Colorado
    '11 TRD Off-Road
  4. Oct 22, 2019 at 4:47 PM
    TireFire
    Olympic Peninsula
    As I said you can swap the whole assembly. The ring gears are actually both 8” but the elocker specific ones have a different cut and won’t go on the open diff case.
  5. Oct 22, 2019 at 4:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    To be honest I don’t know specifics. I just know from what I’ve read on here that it won’t fit. If you want to try, be my guest and post results.
  6. Oct 22, 2019 at 4:52 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Drum to drum will swap no issue.
    Guts for the guts won’t work but it’ll get you riding down the road again.
  7. Oct 22, 2019 at 4:53 PM
    SlimBo84
    Colorado
    '11 TRD Off-Road
    Thanks for the input guys. I will swap it and post the results. If its a bust then I'll flip the axle and make something off of it. I can't lose either way.
    TireFire and MattCowsmasher like this.
  8. Oct 22, 2019 at 4:55 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think I misunderstood your recent post and was quick to jump the gun. When I read:
    "So can I still use the 13 axle assembly and just not have the elocker on it for now? At least to get me on the road? I'm getting this 13 axle at a very good price and won't pass it up if I don't have to. That would give me time to get the original back in working order."
    For some reason I took that as taking the new axle assembly sans guts, adding e locker diff, but without the actuator. Hence the "not have the e locker". Rereading it I don't know why I thought that. Yes you can swap over the entire new axle assembly with no issues. My apologies for the confusion
    MattCowsmasher and TireFire like this.
  9. Oct 22, 2019 at 5:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you are getting the entire assembly, yeah you can bolt it right up without the elocker.... it will actually be stronger due to the thicker ring gear and cradle caps.
    But like stated you are not swapping guts.
    Back in the 1st gen days (3rd gen 4runner) yes you could bolt up an elocker 3rd in a non elocker housing with minimal trimming of the housing, but those days are gone.
    SR-71A and MattCowsmasher like this.
  10. Oct 22, 2019 at 5:32 PM
    CanadianTaco89
    CanadianTaco89 Off road camping rig.
  11. Oct 22, 2019 at 6:40 PM
    TireFire
    Olympic Peninsula
  12. Oct 22, 2019 at 6:41 PM
    CanadianTaco89
    yeah i read it after, lol just trying to some how find a way
  13. Oct 22, 2019 at 7:44 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    That 85 has an 8” diff front and rear, 8” third members can interchange between different 8” housings, including the early trucks, the e-locker low pinion like in the tacoma, and the e-locker high pinion from the front of FZJ80 land cruisers.
    The tacoma sport has a 8.4” diff.
    The 8” and 8.4” third members and housings are not cross compatible.
  14. Oct 22, 2019 at 7:51 PM
    SlimBo84
    Colorado
    '11 TRD Off-Road
    No worries :thumbsup:
