Axle oil changed to Syn.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mullica woods'er, Mar 15, 2011.
  1. Mar 15, 2011 at 2:59 PM
    mullica woods'er
    mullica woods'er [OP] Well-Known Member
    south jersey pinebarrons
    06 trd 4x4
    rear leaf tsb,billies all around.front set at 1.75. 265 duratracs.cbi front hitch.rough contry 9.5 winch/syn.rope.
    Well i got both axles changed today,using Mobil 1.Rear axles was easier.The front diff.needed a pump.Well anyway,in my area(south jersey),nobody carries gallon size gear oil.So i had all qts.Well to make my pump work i got a 1 liter size plastic mouth wash bottle,and the pump fit real good.Just did'nt screw on.And i was able to do the front that way,it worked real good.I would like to know though,since i used Syn.can i go longer than 30k miles??Just curious.Anyway,the job was not to long,i recomend anybody do it.
  2. Mar 15, 2011 at 3:02 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    I did the same, I'll probably change it 50 k miles
