Axle relocation plate
Discussion in 'Suspension' started by cmf21, Jun 12, 2011.
  1. Jun 12, 2011 at 4:00 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Is this item needed when installing the Dakar leaf pack. Thought I read that the axle gets moved forward with the Dakars. I don't want any rubbing.
  2. Jun 12, 2011 at 4:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I believe the Dakars do move the axle forward
  3. Jun 17, 2011 at 6:09 PM
    JBSTRD
    JBSTRD Chicks Dig Body Damage
    Washougal, WA
    98 TRD Limited
    Donahoe CO's, OME Dakars w/Extra Leaf, 33" BFG KM2's, Warn 9.5XP, ARB Bullbar, AllPro Rear Bumper, Budbuilt Skid/Belly, Safari Snorkel
    Yep, some people leave them, others get the axle relocation plate. I did not like how far it moved my axle forward so I purchased this plate from Sky Mfg. (http://www.sky-manufacturing.com/new/detaproduct.php?id=80). It has two holes, one to move it 3/4" and one to move it 1". I used the 3/4" side and everything has been fine. I have been running this setup for about two years with no issues.
  4. Jun 9, 2012 at 7:40 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    Thread revival.
    Was wondering if this is limited to 1st gens...
    Any 2nd gen guys need to relocate their axles when installing Dakars to mitigate rubbing with 33's, namely with 255/85/16?
  5. Jun 9, 2012 at 8:10 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    Thanks. Looks like it did move it slightly forward, based on the 1st pic. Ive got the same wheel BS. Wondering if the extra .2" on my 255/85/16s is enough to cause some rub...
    Ive got the axle relocation plates already, just thinking out loud if I'll actually need them when I do the install.
  6. Jun 9, 2012 at 7:21 PM
    DevL
    DevL Well-Known Member
    Placement in the wheel well won't tell you much since the wheel changes fore/ aft position based on the amount of compression. After the spring goes past parallel is when the wheel moves forward on compression. If those pics are of the wheel and bump in the same position that tire will touch the wheel well when the bump stop touches the frame. My 285/70r17 dont touch with the bump an inch from the frame either... yet when I held the bump to frame over an obstacle it caused my tire to touch the flare and wheel well liner and ripped them off with the continuous contact. Honestly 3/4" is too much spacing... .5" would be ideal but they only come in the 3/4 or 1 inch option unless you go custom.
  7. Jun 20, 2012 at 10:37 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    After installing my Dakars with no AAL I mildly flexed out my rear end to where the stock bump stop was on the frame. No rubbing. I did not add the axle relocation plate. Ill be sure to update the post if anything changes once I actually put the truck through a thorough test next month.
  8. Jun 20, 2012 at 10:48 AM
    DevL
