Axle relocation plates with overload leaf?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Sep 5, 2023.
  1. Sep 5, 2023 at 1:36 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Not uncommon.
    Do a search in 1st gen for relocation plate. Not title. Course you’ll get results for plate & other relocation stuff, like shocks. Anyway, there are references to them here & there & then a rather lengthy discussion in the “what have you done today” forum.
  2. Sep 5, 2023 at 1:43 PM
    Kristi with a K
    Western MA
    This is in park. Level surface. I can see where it used to set under the same circumstances.
    Oh, & my wheelbase is off. Both sides. 129.75. Supposed to be 129.
    Apples to oranges? I don’t know. Alls I’m sayin is it adds up to the axle being back.
    Bugs me. Bugs me because I don’t know why. Wish I did. I’ve had it looked at professionally. Nothing other than the suggestion of longer shackles, which doesn’t set right with me.
    So, why not attempt to fix it….
    HondaGM[QUOTED] likes this.
  3. Sep 5, 2023 at 2:02 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Yeah... i just cant figure out how it got back,something has been replaced or changed to move it exactly 3/4 of an inch back on both sides though...
  4. Sep 5, 2023 at 2:15 PM
    Kristi with a K
    Western MA
    Yup. Well at least it’s squared up ;)
    Bivouac and HondaGM[QUOTED] like this.
  5. Sep 5, 2023 at 7:16 PM
    Austintaco
    Austintaco Well-Known Member
    Patrick
    Austin,TX
    03 DC TRD with some stuff
    King coilovers, Tundra brakes, All pro Expo springs, Timbrens, ARB bumper, All Pro Sliders and Rear bumper, Landcruiser wheels, sold my Flippac, regeared to 4.88’s, ARB front Locker
    Are you referring to the relocation plates to center the axle? Yes, that is an issue with the double cabs. I think Parks Off Road was the first to address this issue. It’s not bad on non lifted truck but gets more noticeable with a lift. I have one on my AP Expo springs with an AAL and it was a bear to get it aligned and tightened down, but I have had no issues one installed. Not sure if this is your issue or not.
    Kristi with a K[OP] likes this.
  6. Sep 5, 2023 at 7:50 PM
    Kristi with a K
    Western MA
    Yes. Those are the plates. Although mine's an x-tra cab. I was just curious if the plates would work with the stock or stock aftermarket overload leaf, being that it's arched downwards. That's why I started the thread. Then many tried to help figure out why my rear wheels are set back.
    I did get one side lined up & then realized I should have bought 2" or 2.25". I bought 2.5", so grinding them down a bit tomorrow.
    Anyway, unless someone pipes in & says NG with the overload leaf, I guess I'll be trying it tomorrow. I can always dismantle if need be, remove that leaf, add a short aal & try it again....
    & thank you for posting that it is a real thing.... I mean issue....
  7. Sep 6, 2023 at 6:40 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    As long as your plate sits flat on the spring it should work.
    If you need a shim could be welded to the plate to keep the spring on a level bearing surface..
    I think we were more trying to figure out what caused your problem then your need to do it.
    Best of luck !! Pictures when this is finished Please!!
  8. Sep 6, 2023 at 9:43 PM
    Kristi with a K
    Western MA
    A little late, however I missed your comments up top.
    The "block" is the relocation plate.
    I thought the leaf at the bottom of the pack was called an overload leaf (not overleaf. not sure were you got that). Please correct me if I am wrong.
    & I thought that whenever operating angles were off to a certain degree, they should be addressed.
  9. Sep 6, 2023 at 9:45 PM
    Kristi with a K
    Western MA
    Ok. Thank you!
    & the help does not go unappreciated. It would have been & still would be great to figure out what caused the problem!
    Will do....
    Bivouac[QUOTED] likes this.
  10. Sep 14, 2023 at 2:55 PM
    Kristi with a K
    Western MA
    As “promised”
    before - off 1in. 22” center hub to fender flare
    After - measures pretty much smack dab in the middle. That’s at 23”, center hub to fender flare.
    Now for my driveshaft angles - they have been off for a while, however I wanted to get the wheels adjusted 1st. I had thought maybe shimming the pinion downward would bring the wheels forward, however according to a Tom woods employee, that’s a no.
    Madjik_Man and Bivouac like this.
  11. Sep 14, 2023 at 3:16 PM
    Bivouac
    Has your spring shifting impacted the ride and handling at all that you noticed??
  12. Sep 14, 2023 at 3:33 PM
    Kristi with a K
    Western MA
    I’ve had some vibes, however I don’t know if this contributed. Probably doesn’t help that the slip yoke was out farther than normal. Course, as I stated, the driveshaft angles are off & have been off. So bottom line is I couldn’t tell you. I’m getting an alignment on Monday, so maybe after I’ll go for a highway run & see if anything’s changed.
  13. Sep 14, 2023 at 3:37 PM
    Kristi with a K
    Western MA
    oh, & there was that weird drifting thing. I think you had asked me if it was like wagon wheels in a track. Now that you mention it ;), I didn’t notice that today. Although it may be that I have acclimated to it, so I’ll try & pay attention to it.
  14. Sep 14, 2023 at 4:01 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    That pic where its off center makes it seem like your driveshaft isn't long enough.
    Have you looked into driveshaft spacers?
    Added length could help level out your d.shaft angles.
  15. Sep 14, 2023 at 5:15 PM
    #35
    Kristi with a K
    Western MA
    You mean the 1st pic in which the wheel is set back?
    This is what the driveshaft looked like before I pulled the wheels forward
    This is now, 2nd & 3rd pic above
    Bivouac likes this.
  16. Sep 14, 2023 at 6:23 PM
    #36
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The 3rd pic looks like the rear wheels are too far ahead.
    An alignment should cure the drifting.
  17. Sep 14, 2023 at 7:30 PM
    #37
    Kristi with a K
    Western MA
    That's just the angle or the phone. Both the 2nd & 3rd are after pics.
    bkhlrTaco's[QUOTED] likes this.
