axle seal replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tennessee98, Oct 21, 2020.
  1. Oct 21, 2020 at 6:51 PM
    Tennessee98
    Tennessee98 [OP] Well-Known Member
    2007 Tacoma supercharged
    I'm replacing both rear axle seals on 07 tacoma and the new o ring I got from toyota is a little bigger than the old one. When installed it sits a little loose. I dont know if the guy at Toyota gave me the wrong one or it's made to sit on the axle that way. I dont have the part number off hand, but I went to my local Toyota dealership and picked it up. Any input is greatly appreciated. Thanks
  2. Oct 21, 2020 at 6:54 PM
    Bishop84
    Bishop84 Well-Known Member
    It should fit snug, you have the wrong seal.
    They need to be tapped in with a mallet.
    TnShooter likes this.
  3. Oct 21, 2020 at 6:57 PM
    Tennessee98
    I have the right seal installed but the black rubber ring that sits on the outside edge of that.
    Bishop84 likes this.
  4. Oct 21, 2020 at 6:58 PM
    Bishop84
    Ooooooooh.
    I'd just reuse the old oring if it fits better. It's more of a dust seal and if its soft its fine.
  5. Oct 21, 2020 at 7:03 PM
    Tennessee98
    Ok thanks, yeah thats what I was thinking of doing. It is still in pretty good shape for 330,000 miles. Just has s little rust on it.
  6. Oct 21, 2020 at 7:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    90301-83002 is the part number for the correct o ring
    Tennessee98[OP] likes this.
  7. Oct 21, 2020 at 7:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Op, you might want to replace your diff breather if it is the original stock one.
    Just because this job sucks, and if that breather gets “stuck shut” it could blow the seals out.
    That’s what I believe happened to mine.
  8. Oct 21, 2020 at 7:51 PM
    Tennessee98
    May just do that. Thanks again for all the advice.
