Axle shaft wobble.
Discussion in '1st Gen. Tacomas (1995-2004)' started by DayMan, Jun 14, 2016.
  1. Jun 15, 2016 at 6:03 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Yes. As Holyfield mentioned above, I went thru the exact same thing.
    Someone noticed that my rear drivers tire had just the slightest wobble in it. At first I thought it had to be an out of round tire, bent rim or a whole slew of wheel weights fell of.
    My truck is not used for wheeling other than some fire trails and I have owned it since new. (2002)
    I could not figure out for the life of me what in the hell was going on. Took the truck home, put it up on jackstands. Started it and noticed the wobble. After swapping both rear tires, there was still a very slight wobble.
    Took it to the shop and ordered a new axle, problem solved. I am going to assume....and always have, that someone must have backed into my tire and bent the flange.
    I have since went to 4340 chromoly axles.
  2. Jun 15, 2016 at 6:05 PM
    Matic
    Tricky Dick
    Easley, SC
    OP, what is your location?
  3. Jun 15, 2016 at 7:03 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    that axle is bent at the flange. right at the base. i don't know where you got the second axle, but it is bent. either that or your original was put back on. and i say thats a posibility because that flange does not look even relatively new.
  4. Jun 15, 2016 at 7:05 PM
    CodeSeven
    Serge.
    Coachella Valley
    also. don't swap the axles. the blacking plates are reversed. the brakes wont function properly. if you do swap them. just bolt them on and dont connect anything else at all whatsoever. the bearing needs to be removed in order to get the backing plates free.
  5. Jul 7, 2016 at 11:16 AM
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    I think I have this problem now. Matic can you help me out with what to order or any way to fix my issue? I'm going to take things apart today and check all other options first.
    @Matic
    Matic[QUOTED] likes this.
  6. Jul 7, 2016 at 6:33 PM
    Matic
    Tricky Dick
    Easley, SC
    Well. Not sure what help i can give. I went to chromo axles and bearings from a "79-85" toyota. I would suggest lifting the rear of the vehicle, pulling the tire and trying to get a runout gauge on the flange.
  7. Jul 7, 2016 at 6:35 PM
    Matic
    Tricky Dick
    Easley, SC
    If your a first gen, i have 1 brand new factory axle here at the house that i had toyota order and install for a week till my chromos came in.
  8. Jul 7, 2016 at 9:21 PM
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    I am and could use it. How much do you want for it. Shoot me a text 864-221-2592
