Axle shim instalation ????
Discussion in 'Suspension' started by brutalguyracing, Jan 12, 2010.
  1. Jan 12, 2010 at 6:06 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    do you just go throught the same process as in the aal install....then just slip the shim in between the leaf pack and axle and re tighten u bolts...ect
    also will i need longer u bolts???
  2. Jan 12, 2010 at 6:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Same process, but you dont have to take the leaf pack apart. Just the U bolts. It goes under the Over Load spring, on the axel.
  3. Jan 12, 2010 at 6:16 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    sweet thanks...... will i need longer u bolts??? aprox. how thick are these???
  4. Jan 12, 2010 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you have 1/2" of thread on your U bolts, you should be fine. Without being there to see the shim, and how long your U bolts currently are, its hard for me to tell.
  5. Jan 12, 2010 at 6:54 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    they are toytec shims.... and i have a half inch of threads showing...
  6. Jan 12, 2010 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be fine.
