Axle shim question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Soulman, Apr 13, 2021.
  1. Apr 13, 2021 at 2:29 PM
    D Soulman
    D Soulman [OP] Well-Known Member
    Dan
    Fargo, North Dakota
    So I have the axle shims from Toytec that have a hole for the leaf pin to go through and is countersunk so that the head of that bolt is partially in the shim and partially in the axle pad/mount to keep things in place. The shop that installed them put the shims between the leaf and a 1/2" block spacer (Icon 3 leaf AAL + 1/2" block to get a little rake). Seems to me they should be on the very bottom, between the block spacer and the axle pad/mount. I think with the small 1/2" block it may not matter much but it seems to me that the optimal position would be below the leaf and spacer. Seems like the current set up may stress the rear part of the ubolt more than necessary. I have emailed Toytec about it but haven't gotten a reply yet. Anyone have any experience with this? Am I explaining it clearly?
  2. Apr 13, 2021 at 2:33 PM
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    Yes they should have put the shim on the bottom. I totally understood what you were saying.
    boston23 likes this.
  3. Apr 13, 2021 at 3:50 PM
    D Soulman
    Dan
    Fargo, North Dakota
    Thank you. Do you have any idea if that is "in writing" somewhere? I would like to have something to bring in with me (other than my opinion) when I ask them to re-do it.
  4. Apr 13, 2021 at 3:53 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It’s just general knowledge. I’d take it back and have them install correctly, otherwise your shims are not at the correct angle.
    Hardscrabble and Dirk Diggler like this.
  5. Apr 13, 2021 at 3:55 PM
    D Soulman
    Dan
    Fargo, North Dakota
    Copy that. That's the plan, just wondering if it is "written" somewhere so I can show them something "official".
    6 gearT444E likes this.
  6. Apr 13, 2021 at 4:02 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It’s shown on their instructions for installing an AAL
  7. Apr 13, 2021 at 4:07 PM
    D Soulman
    Dan
    Fargo, North Dakota
    That's helpful- thanks very much!
  8. Apr 13, 2021 at 4:14 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    It makes me nervous when a shop messes up something so basic. I'd probably have them fix their mistake then take it to another shop to double check their work. All of it.
  9. Apr 13, 2021 at 4:22 PM
    D Soulman
    Dan
    Fargo, North Dakota
    I trust them on most things but they are not very experienced in suspension stuff- no real 4x4 shops around here either. I try to learn as much as I can so it gets done correctly. I know they will fix it for me.
  10. Apr 13, 2021 at 5:57 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    So you have Leaf springs then shim then 1/2" block?
    if you have these and I would have the angle shims on the bottom but I bet if you measure the pinion angle as it is now and afterwards I doubt it will change enough to be measurable. If it isn't a bolt in 1/2" spacer then the way they have them installed is probably the correct way.
  11. Apr 13, 2021 at 6:19 PM
    D Soulman
    Dan
    Fargo, North Dakota
    Agree that the angle would change little to nothing at all and I really think that with a narrow 1/2” spacer it probably makes no difference. But it is a bolt in spacer and shim so that angle introduced into the “middle” just bugs me and definitely would not be good with a larger spacer “after” the shim. Seems like it would force a bend in the u bolts at the point where the shim “turns” toward the front.
  12. Apr 13, 2021 at 9:57 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I doubt adding any degree angle shim is going to cause a u-bolt to bend. The u-bolt pivots at the top and will pull inline with the lower bracket I’ve seen u-bolts like \ | and | / before but I’ve never seen one bend unless something else broke and it was the only thing keeping everything together.
  13. Apr 14, 2021 at 12:15 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Geez,all they had too do take 5 minutes too research the correct install on a computer,amazing so many shops dont know what they are doing.
    Lt. Dangle likes this.
  14. Apr 14, 2021 at 6:45 AM
    D Soulman
    Dan
    Fargo, North Dakota
    Agree, the u bolts also have some play at the bottom with the holes in the bracket being oversized. I guess it just bugs me....
    Thanks for all the replies!
