Axle Shim ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mavrick, Apr 8, 2018.
  1. Apr 10, 2018 at 6:52 AM
    Mavrick
    Mavrick [OP] Well-Known Member
    2015 DCSBOR
    For all you guys with vibs have you actually gone under your truck and did the angle measurements? From the sounds of the comments above it seems like most guys are just guessing without doing the measurements, if so what is keeping you from doing that?
  2. Apr 24, 2018 at 12:39 PM
    JDB 2010
    JDB 2010 Well-Known Member
    2010 TRD OFFROAD CREW CAB SHORT BED
    Did you get your Icon leafs installed and if so what setting did you choose?
  3. Apr 24, 2018 at 5:35 PM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Yes, get under there and simply measure, it'll save you loads of work and mula.
    Also, my other recommendation would be to stick to steel shims, not aluminum...issues with corrosion from dissimilar metals and soft aluminum as well.
    There's some places that'll make custom shims for you, any angle you want in .5 degree intervals.
