Axle Shims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 650H1, Apr 30, 2011.
  1. Apr 30, 2011 at 8:56 AM
    650H1
    650H1 [OP] Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    so I have some pretty good vibrations between like 25-30 mph after doing a 3 inch lift kit. vibrations are in gas pedal, floor, cab. I have switched my driveshaft front to back, but i have the TSB AAL's in the back, plus blocks in the back. so in total i got like an inch more lift in the back than the front. i noticed that when i loaded the bed up with tires last night, the vibrations were gone and the truck rode alot smoother in general. i also do not have a front diff drop kit, but cv angles dont look bad, and im not getting any noise from the front or anything. i ordered some 4 degree axle shims, do you guys think this will help or do i need to spend the 150 bucks to have my driveshaft lengthened at a metalsmith shop? anyone else with a reg cab get vibes after a 3" lift? let me know!
  2. Apr 30, 2011 at 9:00 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    you xould do shims or get a beefed taco CB drop for your carrier bearing
  3. Apr 30, 2011 at 9:09 AM
    650H1
    Michael
    VA
    dont have a carrier bearing in a reg cab, one piece shaft, and its the shortest shaft of any tacomas including the 2wd's...
  4. Apr 30, 2011 at 9:13 AM
    johnw
    john
    orlando florida
    oops sorry axl shims should work try some 2 degree or 3 degree shims and the vibes should go bye bye
  5. Apr 30, 2011 at 9:36 AM
    650H1
    Michael
    VA
    yea i got 4 degree steel shims, because the back came up so much higher than 3 inches so im hoping theyll work, what do you think?
  6. Sep 8, 2011 at 9:37 PM
    BP348
    BP348 Well-Known Member
    San Diego, CA
    2004 DC 4x4
    so how did the 4 degree shims work? i have an 11 reg cab, i lifted it and had the same problem, tried custom driveshaft, 3* shims,no luck. Its just axle wrap, i think the only way to fight it is a whole new leaf pack, i ended up getting the tsb from toyota and it gave me about an inch and a half. let me know how the 4* shims work eh! good luck
  7. Sep 8, 2011 at 9:49 PM
    kingtaco
    kingtaco Well-Known Member
    San Gabriel Valley
    I have the all pro expos and have vibes between 5-10 mph. Tried the cb drop kit from toytec. Still have vibes. Im trying axle shims this saturday. With my add a leaf I had no vibes.
  8. Sep 8, 2011 at 9:51 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I found 4 degree shims too fat.
    See bjmoose installs OME link in my sig for how I measured for and installed rear axle shims on my reg cab.
  9. Sep 9, 2011 at 11:02 AM
    650H1
    Michael
    VA
    the 4* shims i think are too fat, i have a set of 2* shims that im going to put in backwards and see how that works out - advice given from moose. he said thats what yielded the best result for him.
