Axle Shims???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badguybuster, May 30, 2009.
  1. May 30, 2009 at 12:19 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    What the hell are those for? I was on the Toytec website and saw them, what are they for ?????
  2. May 30, 2009 at 12:23 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Rear axle shims are used to change the pinion angle in order to reduce drivetrain bind. Typically used w/ lifts from 2-3 inches and up.
  3. May 30, 2009 at 12:23 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    to correct pinion angle of the rear end after a lift. It helps reduce/eliminate driveline vibrations cuased by a lift and incorrect pinion/u joint angles.
    or heres a site for you...
    http://www.lmgtfy.com/?q=axle+shim
  4. May 30, 2009 at 1:34 PM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    On a leaf truck I like having the pinion 1-2* lower. so when you load it it's running at 0*.
  5. May 30, 2009 at 2:40 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Shims- Used for lifts 2"-3" and makes the axle have more stability and less 5-10 mph vibration from the driveline and axle
  6. May 30, 2009 at 6:13 PM
    badguybuster
    Michael
    Lord, someone needs to write a book, called,"All you need to know about truck lifts.":eek:
  7. May 30, 2009 at 7:07 PM
    Lentsnh
    Truck lifts for Dummies:p;)
  8. May 30, 2009 at 7:22 PM
    badguybuster
    Michael
    Yup. That would be fine with me.
  9. May 30, 2009 at 7:22 PM
    badguybuster
    Michael
    Hey, Chris. I believe that was a hint for you to start writing.
  10. May 30, 2009 at 7:33 PM
    Lentsnh
    Chris already did but it has nd's name on it to make nd sound smarter:):p
  11. Mar 1, 2010 at 9:45 AM
    Sack17
    Sack17 Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    Haha hell I'd buy the book and pay good money for it too lol
  12. Mar 1, 2010 at 10:04 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
